ISO Axle Lift Kit
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15994
Printed Date: 09 Jun 2025 at 4:00pm
Topic: ISO Axle Lift Kit
Posted By: kickhead70
Subject: ISO Axle Lift Kit
Date Posted: 16 Jul 2024 at 12:13pm
Hello all,  i'm in search of an axle lift kit that is no longer made by lippert.  I have a 2017 RP180, but not the Hood River Edition, so it sits a bit low for my taste, and doesn't quite line up with my hitch (which is as low as it goes without a different drop - which may cost as much as a lift).
Does anyone have any resources I could check that I may be able to find one on a shelf in a warehouse somewhere?
thanks!
Wrangler Unlimitied 75th Anniv. Ed.
2017 R-Pod RP180
Posted By: seafans
Date Posted: 18 Jul 2024 at 8:02am
Check Etrailer.  They have several lifts and with  different heights.  Hood River edition is about 2.5" to 3" higher?
Posted By: GlueGuy
Date Posted: 18 Jul 2024 at 11:08am
You can also check with Forrest River, as I think they had a lift kit for non Hood River models. I do not recall the height, but I think it was a 2" lift.
Posted By: Hardwear Hank
Date Posted: 03 Aug 2024 at 2:38pm
I ended up purchasing the lift kit for a Dexter axle for my 192. Two holes line up perfectly, the other two need to be elongated towards center 1/4" each. My trailer now sit about 2 1/2" higher. I got tired of replacing my waste valves because they were so low, they were easily damaged by uneven roads. Very happy with the conversion. The Dexter part# is K71-724-01   the 01 means 1 set for single axle trailers.
Hope this helps someone.
Hardwear Hank
2021-192
Date Posted: 03 Aug 2024 at 2:41pm
The Dexter kit is readily available, but it needs a minor modification see post below from Hardwear Hank
Dexter part# K71-724-01
Hardwear Hank
2021-192
