Dometic 3.7' 3 Way Refrigerator not working
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15576
Printed Date: 08 Jun 2025 at 6:19pm
Topic: Dometic 3.7' 3 Way Refrigerator not working
Posted By: richbar4
Subject: Dometic 3.7' 3 Way Refrigerator not working
Date Posted: 14 Jan 2023 at 12:00pm
First I want to say thanks to everyone on here for there contribution on this forum. I have been behind the scenes utilizing all the information on here to better my rpod experience.
I have a 2016 Rpod 179.  Recently, I went to turn on the refrigerator and I got the warning beep that you would typically here when your try to start with propane and it doesn't ignite the first go around.  Now my fridge gives me the warning beep weather its shore power, battery or propane.  The panel on the front still works and is getting power, it just seems like I cant get the cooling process started.  Has anyone had this happen before or have any things to check for? Thanks in advance.
Posted By: JR
Date Posted: 14 Jan 2023 at 1:24pm
Do you have your battery connected to the trailer's 12v wiring and is the battery in good shape also charged up?  If it's not connected then I am quite sure that the fridge will not operate on gas and there is a possible that it will not function on 120v electric (shore power) and will not work on the battery mode.  The reason for that is that the fridge's control panel uses 12v to control the fridge's operation.  Hope this helps
Jay
179/2019
Posted By: richbar4
Date Posted: 14 Jan 2023 at 1:46pm
Thanks for the response Jay. Batteries are new and in good working order.
Posted By: JR
Date Posted: 14 Jan 2023 at 2:08pm
And connected of course with clean connectors?
Jay
179/2019
Posted By: richbar4
Date Posted: 14 Jan 2023 at 3:31pm
Yes actually new connectors with new batteries
Posted By: Tars Tarkas
Date Posted: 14 Jan 2023 at 9:15pm
I don't recall the specific issue but there have been a couple of times when doing a reset -- turning the fridge completely off for a minute or so -- has gotten mine going again.
TT
FJ Cruiser
Posted By: jato
Date Posted: 14 Jan 2023 at 10:04pm
When you say it doesn't ignite are you able to hear the igniter clicking as it calls for the gas valve to turn on?  If you try the electric (shore power) mode does the cooling stack get warm after 30 minutes or so?  How long has it been since it functioned properly?  Do you have screens over the 2 vents on the back side of the fridge to keep out spiders, bees, and the like?  What happens after you hit for triangle button for 5-10 seconds to reset the fridge and the light goes off?  Does it come back on right away or does it stay off?
