mystery switch
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15553
Printed Date: 08 Jun 2025 at 6:17pm
Topic: mystery switch
Posted By: J.G.S.
Subject: mystery switch
Date Posted: 19 Dec 2022 at 2:13pm
The switch on the top left ?  RPOD 179 , what does it control ?
J.G.S.
Posted By: Winterpod
Date Posted: 19 Dec 2022 at 3:35pm
I would think it is the switch for the outside light
I could be wrong it’s known to happen
Winter pod
2013 R-Pod 178
2007 Silverato 1500 LT.
Trek Stash 8 29er hard tail
Old Town Kayak
Posted By: jato
Date Posted: 19 Dec 2022 at 4:41pm
It is for the outside light.  If light fails to turn on then you will have to replace the bulb.  Easy fix, take a flat screwdriver and carefully insert at the bottom of the fixture, slight twist and lens will pop off.
Posted By: StephenH
Date Posted: 19 Dec 2022 at 5:32pm
Agreed. It is the outside light switch. It would be a good opportunity to replace a non-working bulb with an LED bulb.
Posted By: poohbill
Date Posted: 19 Dec 2022 at 7:04pm
Odd. The switch on our 2016 179 for the outside light is black, with an oversized, unlabeled, cover plate. The HVAC controller is on the left side of the toilet door, with the switch for the toilet light.
2016 179 Gastropod
2017 Ridgeline
Posted By: StephenH
Date Posted: 19 Dec 2022 at 7:14pm
That falls under the rule, "Let no to 'Pods be built the same." Mine is similar to the picture with some variation on relative height of the switches. Only the bathroom light switch is to the left of the door.
Posted By: J.G.S.
Date Posted: 20 Dec 2022 at 1:38pm
The outside light works with the switch that's on the light. The switch for the bathroom light is to the left of the door. I have 48 years in aircraft maintenance and repair. I believe I know how to change a light bulb. I am coming to understand that these campers are built one at a time and are wired differently.
Thanks all for the replies .
J.G.S.
