GFI outlet
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15503
Printed Date: 06 Aug 2025 at 6:20am
Topic: GFI outlet
Posted By: rawest50
Subject: GFI outlet
Date Posted: 23 Oct 2022 at 6:41pm
My GFI will not reset. Is there another way to check it to see if it is the GFI or another problem?
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Posted By: Tars Tarkas
Date Posted: 23 Oct 2022 at 9:23pm
Unplug everything is one way.  If it still won't reset it's easy enough to replace.  They do go bad.
TT
FJ Cruiser
Posted By: offgrid
Date Posted: 24 Oct 2022 at 4:30am
+1 If everything is disconnected and it won't reset then either it's bad (most likely) or you have a wiring fault. Easiest way to determine which is to disconnect from power and replace the GFCI receptacle.  If it still wont stay on then it's the wiring, probably moisture in one of the GFCI protected receptacles. If you don't have easy access to a replacement GFCI receptacle for test purposes you could remove it and temporarily connect the downstream load receptacles to  the line conductors coming in using wirenuts. Be sure to keep track of which pair of conductors are the line side and which the downstream load side., GFCI receptacles have line and load cinnection points.
Posted By: rawest50
Date Posted: 26 Oct 2022 at 3:53pm
Thanks. I have only 1 gfi that the other 3 outlets are on. All other 120v is working. I have had issues before with resetting but this time it will not. Buttons are hard to push.
2017.5 RPod 179
2 Weiner dogs
Posted By: Colt
Date Posted: 30 Oct 2022 at 6:06pm
It won't reset unless it has 120V, either.
John
'16 R-Pod 180
