silicone
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15447
Printed Date: 09 Aug 2025 at 11:53am
Topic: silicone
Posted By: marwayne
Subject: silicone
Date Posted: 29 Aug 2022 at 1:03pm
A while back someone wrote in about a new silicone that will stick to silicone. Can anyone help me out, thank you.
Posted By: offgrid
Date Posted: 29 Aug 2022 at 4:51pm
I think I saw a post at some point stating that Lexel will bond to silicone. But the manufacturer says no. The problem is that silicone's surface energy is very low, I the same range as Teflon. Nothing Dheres well to it.
There is a product called Sil-poxy which is meant to bond tin or platinum cured mold making silicones. But your typical big box silicone is acetic acid so I doubt it would work.
I'd stick to just removing the old silicone, it's not worth the aggravation if/when your new sealant just peals right off.
