wheel seal numbers
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15228
Printed Date: 02 Aug 2025 at 7:12pm
Topic: wheel seal numbers
Posted By: jato
Subject: wheel seal numbers
Date Posted: 19 Apr 2022 at 8:44pm
Would anyone have the seal numbers for the r-pod wheels as they usually get ruined when the bearings are taken out for cleaning/re-greasing.  I know they are double-lipped and have an ID of 1.719" and OD of 2.565".  Thank you.  Guess I am getting old, had it written down along with the above info but cannot locate it.
Posted By: offgrid
Date Posted: 20 Apr 2022 at 11:01am
Should be this one I think. Available on Amazon for $17.
Lippert 333960 RV and Trailer Axle Grease Seal 3500LB 1.719" ID 2.565" OD (2 pack)
Posted By: jato
Date Posted: 20 Apr 2022 at 2:06pm
Thank You OG !
Posted By: gerry demers
Date Posted: 22 Jul 2024 at 12:02pm
Hi! do you know if those seal (333960) will fit for a R pod 2024 with the coil spring suspension?
Gerry
r pod 192 2024
Toyota tacoma 2017
Posted By: jato
Date Posted: 22 Jul 2024 at 2:02pm
You would have to remove from the wheel housing and take to a local auto parts store so they could mike it up and give you the actual size of your bearings/cone.
Posted By: gpokluda
Date Posted: 22 Jul 2024 at 3:14pm
If it has not worn off yet, there should be an axle manufacturer sticker on the axle. That will help you find out which bearings and seals you need. Should look something like this. Note that sticker is from the axle on my trailer and not an Rpod.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
