Murphy bed mattress
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15134
Printed Date: 08 Jun 2025 at 9:24am
Topic: Murphy bed mattress
Posted By: danthefan
Subject: Murphy bed mattress
Date Posted: 03 Feb 2022 at 12:39pm
Just about to pick up our new 192 which has a Murphy bed.  I know I want to swap out the factory mattress for something better, probably a memory foam. Does anyone know the maximum depth of a mattress that will fit while folded, or have any further suggestions on finding the right replacement?
Thanks,
Dan
Posted By: campman
Date Posted: 03 Feb 2022 at 2:35pm
Hi Dan
I responded to your other post, but a simple answer is I would suggest an 8 inch mattress. Make sure it is flexible so it can bend. A memory foam mattress would be a very good place to start.
Andy
Andy and Laurie
'21 RP192
Red-Green
Posted By: MrBlast
Date Posted: 03 Mar 2022 at 3:02pm
Has anyone modified you Murphy bed to allow the window to show more in the 2022 193?
Posted By: lucille193
Date Posted: 13 Aug 2022 at 10:44am
Hello! We have a Murphy bed as well and have found that a foam “topper” makes for a much better night’s sleep. That said, we have decided to remove the folding sofa that the bed opens up on and make it a permanent open bed with a better mattress. Once the sofa is removed the slide out will close when not in use.   This will also give full time light from the window which we also love! Will keep you posted on our endeavor!
Lynn & Lenny
‘21 RP193
‘17 Toyota Tacoma 4x4
State Park Junkies
