Low cost solar kit
URL: http://www.rpod-owners.com/forum_posts.asp?TID=15049
Printed Date: 13 Aug 2025 at 2:49am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Low cost solar kit
Posted By: offgrid
Subject: Low cost solar kit
Date Posted: 16 Nov 2021 at 8:02am
Home Depot is having a sale on Nature Power 440 watt kits for $447 including a 30A charge controller and 750 watt inverter. A buck a watt is pretty good if you need a controller and inverter as well as the modules.
------------- 1994 Chinook Concourse
Posted By: Texas RPOD
Date Posted: 16 Nov 2021 at 11:59am
I'm curious about solar on a RPOD. If you got a larger (than 440) panel, would it run the refrigerator while you are driving?
------------- Texas RPOD
Posted By: Pod People
Date Posted: 16 Nov 2021 at 10:27pm
Most people will operate the refrigerator on propane while driving. some of the newer/larger models may not have propane as an option.
Vann & Laura 2015 RPod 179
https://postimg.cc/0zwKrfB9">
Posted By: offgrid
Date Posted: 17 Nov 2021 at 4:57am
Originally posted by Texas RPOD
I'm curious about solar on a RPOD. If you got a larger (than 440) panel, would it run the refrigerator while you are driving? |
440W should produce around 25-30A at noon on a sunny day..The fridge at 12V takes about 11-12A. So yes 449W should maintain the battery while running the fridge oubder those conditions. But it won't do squat when driving at night or in a cloudy day. Better to plan on maintaing charge on your trailer battery using your tow vehicle alternator while driving. You can of course charge from both sources simultaneously as well.
