Originally posted by GlueGuy
...The GFCI trip is a ground fault in the AC (120VAC) somewhere. One common point between the AC and DC is the converter. Maybe check the wire terminals connecting to the converter.
Many RVs trip home GFCIs without there being any problems with the RV or the home GFCI circuit.
A quick search will reveal many, many discussions on this subject in RV forums. Here's a couple of examples of responses:
My first three RVs could plug into a GFCI without tripping it , my last two cannot . After WEEKS working with the dealer and manufacturer of my new fiver and replacing numerous parts, including the converter/charger ( this was 14 years ago ) , came down to being normal . My first three 5ers , were old enough not to have on-board GFCIs , RVs with on-board GFCIs will trip a GFCI protected power source, in almost every instance. . Possible work around, is to re-set the house GFCI with the RV hooked up, or identify the circuits in the RV that have GFCIs and turn off the RV circuit breakers that feed those circuits .
Or , as stated plug the RV into a non GFCI protected circuit. |
https://www.irv2.com/forums/f54/shore-power-tripping-gfci-in-house-453154.html
OK so what does all of this mumbo jumbo have to do with the problem you are experiencing with your RV? Because GFCI devices trigger at current leakages above 5 milliamps they can cause problem for RVers that have switching type Power Converters in their RV's. These switching type power converters usually have built in input RFI (Radio Frequency Interference) suppression filters to keep high frequency energy off of incoming wiring. During normal operation of the power converter these RFI filters will exceed 5 milliamps of current leakage causing GFCI Devices to trip.
Bottom Line: As long as you are positive that the Power Converter has been installed properly and it is the type I described above; you will always have to plug your RV into a non GFCI protected circuit. |
https://www.everything-about-rving.com/when-my-rv-is-plugged-into-a-gfci-outlet-the-power-converter-is-tripping-the-gfci.html
Of course it's always possible that there is actually something else going on...
------------- 2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
