Water dripping around black water pipe juntion
URL: http://www.rpod-owners.com/forum_posts.asp?TID=14574
Printed Date: 14 Aug 2025 at 9:51am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Water dripping around black water pipe juntion
Posted By: Ricktoon
Subject: Water dripping around black water pipe juntion
Date Posted: 20 Apr 2021 at 4:37pm
I just finished sanitizing my 2021 Rpod 196 and noticed water dripping from the bottom center of the underside of the trailer. The drip is right where the black water drain goes through the bottom cover. I am thinking it is overflow water from the greasy water tank that overflowed into the space between the floor and bottom cover. There is some lack foam caulking but it also a low point where excess water would go. Should I be concerned?
------------- Rick and Ellen B
2019 Chevy Colorado
2021 Rpod 196
Posted By: offgrid
Date Posted: 20 Apr 2021 at 7:37pm
I don't have a bottom cover but that is going to make it more difficult to troubleshoot.
I would say in general that pretty much the worst thing that can happen to a travel trailer is water damage, so I think it needs to be tracked down and either fixed or eliminated as a concern as soon as possible. If you're under warranty I'd take it to dealer and ask them to determine the source of the leak.
------------- 1994 Chinook Concourse
Posted By: Grevan
Date Posted: 08 Jul 2021 at 3:53pm
I'm experiencing the same issue on my RP-195. Did you find what it was?
Posted By: mjlrpod
Date Posted: 10 Jul 2021 at 8:45am
I've had this happen, and talked with others too. We are assuming it's caused by rain. Ofcourse this is not proven, but it seems unlikely we all have the same leak. I've smelled it, it has no odor, and appears fairly clean.
------------- 2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
