Water Panels
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=14003
Printed Date: 18 Jul 2025 at 8:38am
Topic: Water Panels
Posted By: trajoi
Subject: Water Panels
Date Posted: 13 Sep 2020 at 7:12am
I just started with water today. I hooked up a hose to the fresh water (with a filter and pressure nozzle).. the light on the KIB panel inside still shows Empty... am I doing something wrong?
I was able to get hot water (turned on the water heater)
I turned on the water pump
Now, the monitor says the grey water is 2/3 - but the fresh water is still showing empty.
Thoughts?
Thank you!
Tracey
______________________________
2015 4Runner
2021 rpod 196
Posted By: offgrid
Date Posted: 13 Sep 2020 at 7:39am
If you connect to city water that does not fill your fresh water tank. To fill the fwt you need to put your hose in the tank fill and let it run in, takes a few minutes.
When you are on city water you do not want or need the pump to be on. The pump pumps water from the fwt. If the fwt is empty you should leave the pump off.
You would have to run quite a bit of water to get your grey tank to 2/3 full, which is 20 gallons. Probably that would take around 10 minutes running a faucet.
One more thing, don''t depend too much on the little level lights, they are notorious for being inaccurate. You can see the water level in the fwt by looking at it, its translucent. Best bet with the gray and black tanks is to start with them empty before setting up camp, then dump before you leave.
Posted By: trajoi
Date Posted: 14 Sep 2020 at 9:23am
Thank you!
