Chassis Ground
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=13801
Printed Date: 18 Jul 2025 at 6:03am
Topic: Chassis Ground
Posted By: fwunder
Subject: Chassis Ground
Date Posted: 20 Jul 2020 at 12:26pm
I'm moving wires around.
I currently have two auxiliary input/output SAE cables connected to my dual GCs - positive and negative connected to battery bank. I use them for solar input and/or aux output like water transfer pump, fans, lights, etc.
Question:  Is there any disadvantage to running negatives to chassis?
Thanks!
Posted By: offgrid
Date Posted: 20 Jul 2020 at 2:40pm
It depends. The battery negative should be connected to chassis ground. But its better to run a negative conductor directly for heavy currents because there is usually a higher resistance in a connection via the chassis which results in a larger voltage drop than is preferable.
Posted By: fwunder
Date Posted: 20 Jul 2020 at 2:43pm
Thanks offgrid! I sorta suspected something like that.
