Screw cover vinyl
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=13690
Printed Date: 06 Jun 2025 at 1:30pm
Topic: Screw cover vinyl
Posted By: Buckeye
Subject: Screw cover vinyl
Date Posted: 22 Jun 2020 at 2:33pm
The vinyl trim on our slider that covers the screws has split at the top. Two questions:
1. Common?
2. How is it replaced? Easy or difficult?
Craig-retired teacher of the blind
Carol-retired legal admin asst
Spot and Sam-the miscreant Shih-tzus
"Politically incorrect with no real changes expected...”
Former 2017 Rpod 180
F150 5.0 4x4
Posted By: StephenH
Date Posted: 22 Jun 2020 at 3:22pm
Very common. Look on Amazon. It just bends and slips into place with a little effort.
This is what I bought. It is much heavier than the original insert. https://smile.amazon.com/JR-Products-10111-Premium-Insert/dp/B0031Y7Z0A/ - https://smile.amazon.com/JR-Products-10111-Premium-Insert/dp/B0031Y7Z0A/
Try to not stretch it as you are installing it and do put the cap with screw on at the ends. It will help keep it in place in case there is any shrinkage. I ordered it in May, 2018 and it is holding up very well. The original wore out and was replaced by the dealer with another cheap strip. When we went to visit our daughters out west, I noticed it cracking in the Arizona heat. Since ordering this, I have not noticed any issues with it.
Posted By: trjeep
Date Posted: 11 Jul 2021 at 10:37pm
Any ideas / tricks for replacing the trim tape on the awning (passenger) side of the RPOD?  The awning covers the trim tape track.  I'm hoping that I don't have to remove the awning to replace the tape.
Tony
2017 RP180
Posted By: StephenH
Date Posted: 12 Jul 2021 at 9:26am
After I pulled the old trim tape out, I just pushed the end of the trim tape as far as I could under the awning frame. I figured that the awning frame protects the screws in the part I could not get the trim to. Then I used a couple of small pieces of pool noodle and pushed them in the opening to both seal it and keep insects out. So far, it seems to have worked well.
Posted By: trjeep
Date Posted: 13 Jul 2021 at 2:28pm
Thanks StephenH!  Sounds like that's the ticket.
Tony
2017 RP180
