R Pod 172 water pump problems
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=13662
Printed Date: 17 Jul 2025 at 5:55pm
Topic: R Pod 172 water pump problems
Posted By: mnnorthshore35
Subject: R Pod 172 water pump problems
Date Posted: 14 Jun 2020 at 10:06am
Hello,
I picked up a 2009 R pod 172 and in the process of de-winterizing.
So when I hook up the city water everything works great, but when I try to use the fresh water, all I get is the faucet trying to spit water out with no luck.   I took the cap of the faucet & located the hot water bypass valves and turned all of them.   Still nothing.
The hot water heater bypass valves are below the dinette, it has three, one red & two blue.
Any advice would be appreciated.   I also would like to take out the bunk beds and make it into a small living room with a chair & tv .   Anyone ever do that and would it affect the integrity of the structure by doing so?
Thanks,
Scott
Posted By: offgrid
Date Posted: 14 Jun 2020 at 10:18am
If it hasn't been used for awhile its probably just lost its prime. You can try switching the pump inlet from the fresh water tank over to the suction line used for pulling in antifreeze. Place that line in a couple gallon bucket full of water, turn the valve, and see if that fixes it.
Posted By: Tars Tarkas
Date Posted: 14 Jun 2020 at 2:10pm
First, do you have water in the potable tank? Is the valve for antifreeze suction tube, probably under the sink, closed?  Is the water heater full?  In not, you'll get nothing but air from the HW tap until it fills.
I'm kind of betting on the antifreeze valve. Let us know if you figure it out or have more questions.
TT
FJ Cruiser
