Where to.....
URL: http://www.rpod-owners.com/forum_posts.asp?TID=13543
Printed Date: 15 Aug 2025 at 1:10pm
Topic: Where to.....
Posted By: ArenaBlanca
Subject: Where to.....
Date Posted: 11 May 2020 at 11:12am
We have a 195 (an upgrade for us from a 179.)  We are very happy with the 195 although we haven't gone anywhere it it yet due to the closures.  The dealer included a toilet paper holder but I haven't figured out where to mount it.  It needs to screw into something other that the thin stock they use for walls and the brackets are too wide for any of the cabinet face frames.  I thought about mounting it inside the sink cabinet but then you can't open the cabinet door when you are sitting down.
Does anyone have any suggestions??
Enjoy Life!!
Posted By: podwerkz
Date Posted: 11 May 2020 at 11:41am
You wont need that...cuz...
Nobody can get toilet paper.
Posted By: StephenH
Date Posted: 11 May 2020 at 11:51am
If you use short anchors (make sure they are less than an inch in length), that will help spread the force so that it will be less likely to pull out of the wall. How about using a holder that hooks over the top of the door? We use one of those in our 179. It fits on the edge of the opening that is under the sink in our 179. This is the one we use:
https://www.walmart.com/ip/Mainstays-Chrome-Over-The-Tank-Roll-Reserve-Carded-Pack/23598550 - https://www.walmart.com/ip/Mainstays-Chrome-Over-The-Tank-Roll-Reserve-Carded-Pack/23598550
It is also handy because we can take it out when we need to use the shower. Since we have a wet bath, it helps to keep the paper dry.
Posted By: mjlrpod
Date Posted: 11 May 2020 at 1:08pm
I have a 195, I attached it to the left of the commode, just below the netted area. Easy to reach when needed, out of the way otherwise.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted By: Capt Kidd
Date Posted: 11 May 2020 at 1:22pm
I have a 196 and I attached mine to the left of the toilet with a command strip./  Seems to be holding fine.
The Pirate's Pod
Date Posted: 11 May 2020 at 1:25pm
That's the left side of the toilet as you face it.
The Pirate's Pod
