Wheel seals (part numbers, etc.)
URL: http://www.rpod-owners.com/forum_posts.asp?TID=13049
Printed Date: 08 Jul 2025 at 6:13am
Topic: Wheel seals (part numbers, etc.)
Posted By: spentwings
Subject: Wheel seals (part numbers, etc.)
Date Posted: 19 Jul 2019 at 10:47am
2016
RPod R179
I need to purchase wheel seals from a dealer.  They ask for VIN and axle tag number.
VIN retrieval was no problem, but I find no info online or in my owner's manual regarding an axle tag number.
Any help much appreciated!
Good decisions come from experience. Experience, well.... that comes from bad decisions.
Posted By: podwerkz
Date Posted: 19 Jul 2019 at 1:52pm
That axle tag should be on the axle itself. Crawl under the trailer and look for it...write down the number or take a picture of it with your phone.
Posted By: offgrid
Date Posted: 20 Jul 2019 at 5:07am
You most likely have a Lippert 3500 lb axle in which case the correct seal is Lippert part number 122087. You can order these or equivalent on the 'zon or from etrailer or another online source of your choice.
Here's a link to the Lippert manual, the parts breakdown is on page 25.
https://www.carry-ontrailer.com/wp-content/uploads/2015/03/Lippert-Axle-Manual.pdf - https://www.carry-ontrailer.com/wp-content/uploads/2015/03/Lippert-Axle-Manual.pdf
Posted By: seafans
Date Posted: 20 Jul 2019 at 11:04pm
Steve here:
I have a RP-18o and when we purchased the pod the brake liners were soaked with grease.  During the brake shoe cleaning and repacking the bearing I found that NAPA has the original seals for about $1.79.  If you like I can go thru my receipts and find the NAPA part number and give it to you.  Only as a suggestion I purchased a set of wheel bearings and and extra seal that is kept in the trailer.  I hand packed the bearings and sealed them in a seal-a-meal vacuum bag.
