My version of axle support
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12804
Printed Date: 17 Aug 2025 at 5:03pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: My version of axle support
Posted By: marwayne
Subject: My version of axle support
Date Posted: 29 Apr 2019 at 9:16pm
https://postimg.cc/jC7YfPRp"> https://forensicanthropologist.net/ - what are the duties of a forensic anthropologist
https://postimg.cc/0b5gB3Ys">
https://postimg.cc/HjpPYMV0">
https://postimg.cc/0zbyLrYP"> https://forensicanthropologist.net/salary - how much money does an archaeologist make a year
https://postimg.cc/yDqGzb9x">
https://postimg.cc/c6phK8J5"> https://falloutfacts.com/legendary-deathclaw-fallout-new-vegas - the thorn fallout
------------- If you want something done right, do it yourself.
Posted By: crw8sr
Date Posted: 29 Apr 2019 at 10:10pm
You have to market that!!!!!!!!!!!!!!!!!
------------- Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Posted By: Toyanvil
Date Posted: 29 Apr 2019 at 10:37pm
Posted By: offgrid
Date Posted: 30 Apr 2019 at 7:00am
That looks great marwayne.
But.....
The weakest points are just outboard of where the axle tube is attached to thr frame supports. The tube gets pushed up under load at those points. I might be missing something but I don't see in the pics where you have reinforced those areas.
------------- 1994 Chinook Concourse
Posted By: Awchief
Date Posted: 30 Apr 2019 at 8:33am
Lippert torsion axles come with an 11 year full warranty.
https://www.lci1.com/assets/content/support/forms/OEM_Axle_and_Running_Gear_Standard_Warranty_effective_1_1_2017_FINAL.pdf - https://www.lci1.com/assets/content/support/forms/OEM_Axle_and_Running_Gear_Standard_Warranty_effective_1_1_2017_FINAL.pdf
------------- Michael
Posted By: offgrid
Date Posted: 30 Apr 2019 at 8:56am
Interesting....
And useless to the end user. This is a warranty to the OEM (FR). Also it excludes overloading and unreasonable use.....as determined by Lippert in their sole discretion. So, FR would have to want to take on your case, and be willing to attempt to prove that your axle wasn't overloaded or encountered unreasonable use (like say hitting a curb). Good luck with that
Basically, there is no joy in Mudville with warranties like this for an individual user. We can let one of our resident laywers weigh in but I'd guess you'd need to show a pattern of similar failures and iniitiate a class action suit to get any traction.
And pretty clearly the axles aren't failing at loads below 3500 lbs just sitting there. The argument would be what is a reasonable safety factor to apply to an axle rating. I've seen numbers in the 2.5-4x range in the vehicle world to address bump loading, but it doesn't look like there is a single accepted standard. What the indiviudual manufacturers use internally is a trade secret. I think the Lippert axles as used on the rPods have a load factor of around 2.5 to 3.0, so toward the bottom end of the range, but not way out of the norm. Just my $0.02.
Posted By: lostagain
Date Posted: 30 Apr 2019 at 9:05am
For most of us the warranty is not worth a Venezuelan Bolivar Fuerte [if you don't know what that's worth, look it up just for fun] since it is not transferable to the owner of a second hand trailer. The warranty doesn't cover altered axles, such as was done by Toyanvil and marwayne. And it doesn't cover damage related to the attachment of the axle to the frame, which is precisely the problem with its use on the Pod.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Posted By: GlueGuy
Date Posted: 30 Apr 2019 at 9:35am
Unless there is something outboard of the frame members that I'm missing, then I'm inclined to agree with offgrid. The weak point in the axle design is the long moment arm outboard of the frame attach points. The basic issue is the wheels & tires & torsion arm are cantilevered outboard of the frame. The solution that Toyanvil came up with and the one that offgrid did to reinforce that area look like viable solutions to me.
------------- bp
Posted By: marwayne
Date Posted: 30 Apr 2019 at 10:24am
I did the same as Toyanvil. Toyanvil stated that nothing is attached to the frame but to the risers, that's what I did.Toyanvil attached on the outside, I attached it on the inside.
Posted By: StephenH
Date Posted: 30 Apr 2019 at 11:51am
Originally posted by marwayne
I did the same as Toyanvil. Toyanvil stated that nothing is attached to the frame but to the risers, that's what I did.Toyanvil attached on the outside, I attached it on the inside. | It looks like yours is the middle ground between the other two designs.
It will be interesting to read updates on how each of the three designs work in real life.
------------- StephenH
Date Posted: 30 Apr 2019 at 12:02pm
marwayne, as always your work is executed exceptionally well. Do you plan on coming up with something to support the part of the axle that extends from the frame/risers to the brake drum? How do you you plan on managing the stress put on that part of the axle now that the part inside the frame is reinforced?
Sonoma 167RB
Our Pod 172
Posted By: marwayne
Date Posted: 30 Apr 2019 at 12:50pm
All I'm trying to do is to prevent the axle to go into a negative camber
Posted By: offgrid
Date Posted: 30 Apr 2019 at 12:51pm
i think there is a misunderstanding here of the forces involved. As GlueGuy says, the issue is that the cantilever created by the inboard axle mounting points to the frame is too long. Toyanvil's and my approaches adress this by supporting the axle tube outboard of those mounting points, reducing that cantilever load on the axle tube.
Unfortunately, Marwayne's approach does not provide this support.
Here is the load diagram and the stress equations (just think of it as flipped upside down).
https://www.engineersedge.com/beam_bending/beam_bending7.htm - https://www.engineersedge.com/beam_bending/beam_bending7.htm
Posted By: marwayne
Date Posted: 30 Apr 2019 at 1:16pm
Look I'm not an engineer I'm a finishing carpenter. Here is my point, since toyanvils design the down pressure is not vertical but in an angle therefore there is a lot more pressure against the riser than on my design. But as I stated before I'm not an engineer. I won't be able to try it fore a while, because it is snowing here and - 4 C.
Posted By: marwayne
Date Posted: 30 Apr 2019 at 1:39pm
It would be nice if I was able to add Toyanvils design to the outside of my axle, but that is beyond my capability.
Posted By: podwerkz
Date Posted: 30 Apr 2019 at 1:45pm
I'm no engineer but it seems to me that limiting the very slight downward movement of the center of the axle tube (during heavy loading, hard bumps and potholes) will INCREASE the forces on the axle tube just outboard of the frame attachment points.
If the middle tube section has no 'give', the deflection will be transferred outward, or so it seems to me.
------------- r・pod 171 gone but not forgotten!
Posted By: offgrid
Date Posted: 30 Apr 2019 at 1:48pm
Look I'm not an engineer I'm a finishing carpenter. Here is my point, since toyanvils design the down pressure is not vertical but in an angle therefore there is a lot more pressure against the riser than on my design. But as I stated before I'm not an engineer. I won't be able to try it fore a while, because it is snowing here and - 4 C. |
Marwayne, I understand you're not an engineer. I am, and all I'm trying to do is help.
Your point about Toyanvil's design is valid, it does create a moment (torque) on the riser. That's why I suggested he bring the diagonal load up as high as possible to keep the moment load on the riser down to minimum. He did that and I think he'll be OK, but I didn't run the numbers. In my design, all the forces are vertical so its not a problem.
What GlueGuy and I are pointing out is that your design doesn't adress the underlying problem which is a cantilever which is too long. The bending stress on the axle tube starts at zero out at the wheels and reaches a maximum at the axle supports. The longer the distance between the wheel and the support point (the cantilever length) the higher the bending stress is.
If the bump loads on both wheels are the same (say you go over a speed bump too fast) then the stress on the axle tube is the same between the supports as it is at the supports. Changing the distance between the supports (which is what your design does by adding an additional support point in the center) doesn't change the bending stress on the tube. So, you will still reach the yield stress point of the steel at the same bump load as if you didn't add your support. Once you hit yield the steel tube will not return to its original curvature and you'll have negative camber.
I hope that all makes sense.
Re testing to see if any one of these solutions solves the problem is not really practical or necessary. You'd have to set up a controlled experiment where you overloaded your trailer axle with the reinforcement by an known amount, and show that everything is OK. Then remove the reinforcement and load it to the same point and show that the axle fails. Oops, now you have a bent axle  .
No one is going to actually do that and its not necessary. The engineering of cantilever beams is very well understood. Buildings are designed using these same formulae (no testing needed) and occupied by thousands of people safely.
Date Posted: 30 Apr 2019 at 2:34pm
From a legal perspective it seems that the bendy part of the axle is outside of the frame rails and that's what you need to ultimately reinforce with out moving the problem somewhere else. So, either offgrid's or Toyanvil approaches ought to help reduce the stress. I think Toyanvil's solution is much more appealing from a design aesthetic point of view, and like marwayne's work it was beautifully executed, but for simplicity and reducing the risk of moving stress points to uncontemplated places, the elegantly simple design of offgrid's angle iron support under the full length of the axle seems like it strengthens the bendy spot of the axle while not moving the force to create another weak spot. But, what the heck do I know, I'm a lawyer not an engineer.
So I vote that marwayne and Toyanvil get together and make a kit using offgrid's design and I'll be one of the first to buy one. [note to marwayne: My dad moved from northern Minn. to avoid the kind of cold you have right now and ended up being nice and warm in Bakersfield. You could head down there for a couple months in the winter as we go to Colombia, to escape the cold.  ]
Sonoma 167RB
Our Pod 172
Posted By: Toyanvil
Date Posted: 30 Apr 2019 at 10:48pm
Marwayne, I like it and may build one for my trailer. I looked at adding a crossbar to mine, but did not think about adding a support in the middle. I was just looking at supporting my lift blocks. If I were to do it again, I would weld a crossbar from one lift block to the other and make it all one piece. I think yours will work since a Torsion axle is almost solid the first 20 inches or so and hollow in the center. The problem with the axle warranty, is FR did not build the RPOD's with the right frame rail spacing. Axle companies recommend the frame rail to hub face not be over the 9 inch max, RPOD's are 15 inches. The sad thing is, it looks like FR is still doing it 10 years later.
Posted By: offgrid
Date Posted: 01 May 2019 at 5:09am
Originally posted by Toyanvil
Marwayne, I like it and may build one for my trailer. I looked at adding a crossbar to mine, but did not think about adding a support in the middle. I was just looking at supporting my lift blocks. If I were to do it again, I would weld a crossbar from one lift block to the other and make it all one piece. I think yours will work since a Torsion axle is almost solid the first 20 inches or so and hollow in the center. The problem with the axle warranty, is FR did not build the RPOD's with the right frame rail spacing. Axle companies recommend the frame rail to hub face not be over the 9 inch max, RPOD's are 15 inches. The sad thing is, it looks like FR is still doing it 10 years later. |
In reality the axle section between the supports does nothing to help with axle bending, so supporting it in the center doesn't help. There really isn't a need for the axle tube between the supports at all, other than to reduce the risk of twisting the trailer frame. That's how these work:
https://timbren.com/blog/products-page/asr35hds11/ - https://timbren.com/blog/products-page/asr35hds11/
But even with outboard frame rails you can't get the wheel loads right under the frame members so with the Timbren axles you need a crossbar to carry the moment (torque) so you don't twist the trailer frame. You potentially have the same issue with your axle end supports but I think you're OK as is. A crossmember couldn't hurt though.
The rubber in the axle tube ends won't do anything to support the steel tube, its way too flexible. The tube is very stiff, so the deflection at which it fails is pretty small, only about 0.2 inches IIRC. That's why a flat tube with no crown is a clear indicator of a failed axle.
If someone really wanted to make up a welded part that would solve the axle bending problem without replacing the axle itself, I think the best approach would probably be to fabricate a tube the same length as the axle tube that attaches to the frame and axle at the existing locations and also extends outboard to provide a vertical downward support for the axle ends. It wouldn't need to be clamped to the axle tube at the ends (or the center) to work.
The part would also act as a replacement for the riser kit. Call it an axle reinforcement/riser kit combo. If you made it up from the same tube section as the axle it should roughly double the load capacity of the existing tube and provide about the same additional height as the existing riser kit.
Posted By: Awchief
Date Posted: 02 May 2019 at 7:37am
Offgrid, Interesting response. For what it is worth, after posting this link on another forum I received a PM from a member. Their 6 year axle had failed on one side. After making a couple of phone calls to Lippert and follow up call from their shop Lippert is replacing their axle to include all labor and freight charges.
Posted By: offgrid
Date Posted: 02 May 2019 at 2:24pm
Great to hear Lippert is taking responsibility in at least one case. Do you have any particulars on what actually failed and the conditions?
If the other trailer was an rPod then Lippert made both the axle and the trailer frame, so if the failure was a bent axle tube it would be difficult for Lippert to say they weren't accountable for effects of the inboard frame rails on their axle.
Posted By: Awchief
Date Posted: 02 May 2019 at 4:05pm
Hopefully she will post follow up information and photos. i am guessing it might take several weeks. If I find out more I will pass it on.
Posted By: podwerkz
Date Posted: 02 May 2019 at 4:20pm
Now THAT'S what I call, 'axle support'!
Posted By: riotkayak284
Date Posted: 03 May 2019 at 5:54am
Guys, while I am not an engineer, I am an attorney. I would like to point out that any modification to the axle will most likely void any warranty. With that being said, I do understand the reasoning.
Posted By: offgrid
Date Posted: 03 May 2019 at 7:15am
+1.
Assume no warranty if you modify the axle in any way. Lippert's warranty specifically excludes that. OTOH, none of the reinforcement fixes we've worked on here actually modify the axle itself, and they are all easily removable. If mine fails even after reinforcement I'll upgrade to a 5200 lb one which wouldn't be covered anyway.
Posted By: Toyanvil
Date Posted: 03 May 2019 at 8:23am
If you install a 5200lb torsion axle you will only change your problems, you will be shaking your trailer apart. I have seen trailers with over sized axles shake the AC to the pint it is bending the roof down. If I change my axle, I be installing 3500lb leaf springs with 5200lb axle.
Posted By: offgrid
Date Posted: 03 May 2019 at 9:50am
I don't think ride would be a problem in my case. My 179 is heavy, it sits right at the current 3500 axle load limit. So, I would still be at a comfortable 67% of maximum axle load rating on the 5200lb axle. IMHO, heavy rPods really should have had a 5200 lb axle in the first place. Also, torsion axles have a better ride than spring axles do. Many people have done this same upgrade.
But, if the axle failures are indeed in the tube itself and not the rubber cords, spindle, or torque arm, the reinforcement will take care of the problem and give me about a 50% increase in capacity (which is also about 5200 lbs).
If you put a spring axle system under there how do you maintain the ride height and still have clearance for the springs and axle travel?
Posted By: StephenH
Date Posted: 03 May 2019 at 9:51am
A warranty is only good if the manufacturer can't weasel out of it by claiming that the owner abused the axle by overloading it or hitting curbs or other reasons. My axle replacement wasn't covered because Lippert said that it was out of warranty. Axles should not fail. Part of the problem is FR's decision to have the mounts so far from the wheels. To me, that is a design flaw that cost me a lot of money I should not have had to spend to replace an axle that should not have lost its camber.
Posted By: GlueGuy
Date Posted: 03 May 2019 at 2:23pm
Isn't the axle rated at 4400 or 4500 (or thereabouts) if the mount points are further out closer to the wheels? My read on that is that if you can support the axle further out, you gain the advantage of the higher rating without having to compromise the ride quality.
------------- bp
Posted By: Toyanvil
Date Posted: 03 May 2019 at 3:10pm
Axles are rated based on the mounts being in the right spot, unlike our RPODs. A 5200lb axle mounted on the stock RPOD mounts will not be rated anywhere near 5200lbs. and may bend just like the 3500lb axles are. The only right way to fix the problem is to move the axle mounts outboard. If you move your mounts outboard to where the axle should be, your stock 3500lb axle will not be a problem. Shame on FR for not doing the right thing 10 years ago and still doing it today.
Posted By: offgrid
Date Posted: 03 May 2019 at 3:28pm
Originally posted by GlueGuy
Isn't the axle rated at 4400 or 4500 (or thereabouts) if the mount points are further out closer to the wheels? My read on that is that if you can support the axle further out, you gain the advantage of the higher rating without having to compromise the ride quality. |
Good question.
Lippert has 3500 lb and 5200 lb torsion axle ranges. When I called them to see if I could buy a higher rated axle and read him the model number (which includes the frame attachment spacing) the first sales tech I talked to said they could sell me a 4400 lb rated axle but it was "identical in all respects" to the 3500 lb one I already had, other than the label. He said he checked the configuration with his engineering staff to be sure.
But when I called back later to confirm I got a different sales tech who said they were told not to tell people that and said I would need to buy a 5200 lb axle if I wanted a higher rating.
If the 4400 lb axle was truly "identical" it would have the same inboard mounting points. So I'm left wondering what the first guy I talked to and his engineering group were thinking. The only thing I can think of is that they have a customer who buys that same axle and has them put a 4400 lb label on it. We know that Lippert provides the same 3500 lb axle to FR which they derate to 3000 lbs for the smaller rPods, so maybe they do the opposite as well on some other trailer?
Here's how I look at it. if my axle fails in spite of the axle tube reinforcement it will presumably be some other component besides the axle tube that fails, like the torsion arm, rubber cords, or the spindle, all of which are most likely the same on any axle in the 3500 lb product range. So if any of those fail it wouldn't make sense for me to get another 3500 lb axle anyway.
If I ever do have to get another axle I think I'll try a Dexter one, they seem to be perceived in the industry as having a better quality product.
Posted By: mcarter
Date Posted: 03 May 2019 at 5:36pm
Interesting comment, way back in these posts I said I had a Dexter axle, etrailer told me the Dexter axles did not exhibit the bending issue. I posted same. I still have a Dexter axle without mods that has never had an issue. I can't find one report of a bent Dexter, if you know different please say so. Till then, appears folks are modding crappy axles and when basic fix is obvious.
------------- Mike Carter
Posted By: Toyanvil
Date Posted: 03 May 2019 at 8:31pm
Before I bought my RPOD I looked into the axle problem and found the RPOD with Dexter and Lippert axles had the same problem, or I would have just bought an Dexter axle and been done. I also found most people don't know their axle has lost it's camber, if your trailer wheels are not straight up or real close to it your axle has lost it's camber. If you were to call Dexter or Lippert axles and told them you were building a trailer and give them the RPOD spec, my are 89.5 hub to hub and 59.25 mount to mount that equals 15 inches overhang each side. They will tell you, you have way to much overhang and your axle will lose capacity rating. So far my supports are working great, zero change in 500 miles. If my loses camber, I will change it to leaf spring and air bag like the last trailer I built. Here's a picture of the last one I did, before brakes. I built this axle over-kill to handle the over size tires and overhang, I think my overhang is only 6 or 7 inches.
Posted By: offgrid
Date Posted: 04 May 2019 at 6:53am
Originally posted by mcarter
Interesting comment, way back in these posts I said I had a Dexter axle, etrailer told me the Dexter axles did not exhibit the bending issue. I posted same. I still have a Dexter axle without mods that has never had an issue. I can't find one report of a bent Dexter, if you know different please say so. Till then, appears folks are modding crappy axles and when basic fix is obvious. |
Its going to depend a lot on how you load your trailer and where you travel with it. IIRC mcarter, you don't boondock much so you probably roll out relatively light on your axle and probably don't hit a lot of unsurfaced roads? WDH tension adds load as well. Do you know what your loaded axle weight is? Mine really is right around 3500 with my WDH tensioned, no doubt over 1750 on the slide side and under on the curb side.
As has been pointed out a few times, most folks never have a problem with their axles getting bent. That being said, I would switch to a Dexter if I replaced my axle both because they do seem to have a better reputation in some circles but also just because I didn't get a straight answer from Lippert. That kind of thing turns me off just on principle.
But for about $100 I figured I'd start with the cheapo reinforcement option and see if that takes care of the problem. I'd have well over $1000 into a new 5200 lb axle, brakes, and wheels. And if it ain't broke don't fix it, its not like its going to leave me stranded somewhere. The failure is that it just picks up some negative camber.
Posted By: mcarter
Date Posted: 04 May 2019 at 6:13pm
All good points. I am not a boondocker as I don't believe the Pod is best suited for that. I have more concentrated on my tongue weight and do not know my loaded axle weight. I agree the folks I have consulted have a favor to Dexter over Lippert and by know means disagree with Toyanvil, but I'm not getting same info. The folks I have consulted, and to be honest without camber issues, have all recommended Dexter over Lippert. I am not a WDH user. End of the day I'm pretty easy on my Pod, improved camping areas, etc.
Posted By: offgrid
Date Posted: 05 May 2019 at 6:14am
All good points. I am not a boondocker as I don't believe the Pod is best suited for that. I have more concentrated on my tongue weight and do not know my loaded axle weight. I agree the folks I have consulted have a favor to Dexter over Lippert and by know means disagree with Toyanvil, but I'm not getting same info. The folks I have consulted, and to be honest without camber issues, have all recommended Dexter over Lippert. I am not a WDH user. End of the day I'm pretty easy on my Pod, improved camping areas, etc. |
I agree. I don't think you'll have any issues the way you're using your pod, unless you get really unlucky and drop into a giant pothole or something. In my case, I ran around (carefully!) all last summer on unsurfaced roads with a WDH on a heavy trailer and didn't bend my Lippert axle, but I don't figure my luck would have held out too much longer doing that.
