2019-189 Recliners
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12726
Printed Date: 12 Jul 2025 at 11:40am
Topic: 2019-189 Recliners
Posted By: harrypodder
Subject: 2019-189 Recliners
Date Posted: 03 Apr 2019 at 7:59pm
If anyone with a 2019 189 thinks the jack-knife sofa is very uncomfortable to sit in while watching TV like we did here is the set-up from Rec-Pro that we just installed. From the "Charles Collection" looking at the recliners a 22" recliner with no arms on the door end next to it a 9.5" console then a 29" Right arm recliner then a 12" console. Whatever set-up you choose make sure the recliner will clear the slide when extended. Also be sure to measure correctly because even though Rec-Pro has been great to deal with if you read there policy if you have to return something you pay the freight back and since it ships free they will also deduct the cost of freight they paid to ship it to you so your probably talking around a couple hundred dollars in freight cost if you want to send a chair back and get something else.
side note: Man are these recliners comfortable and they extend far enough back you can sleep in them and they only need the same amount of back wall clearance as the jack-knife did. One negative you will lose most of your rear storage.
