Rpod dreamer, now lover, but what do I DO???
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12716
Printed Date: 08 Jun 2025 at 9:25am
Topic: Rpod dreamer, now lover, but what do I DO???
Posted By: AgedWhine
Subject: Rpod dreamer, now lover, but what do I DO???
Date Posted: 31 Mar 2019 at 10:02pm
We have looked for some time. Walked in many. Even checked other small units. Some are so small that I felt like I had to move something just to blink. Others may be roomier but you almost need to donate a kidney to afford it and then one hail storm and it looks like the surface of the moon šŸŒ™.  We are not new to having an RV, but after living fulltime in a 5th wheel, we are ready for something that is easy to pull, park and play (PPP). In all our hours of research, looking and dreaming. The decision has been made! The winner is rpod. We have placed our order for the new 195!  We are so excited that all my wife and I talk about is the new child in our family.  But now the questions begin...
1.  Should we have the slide-topper installed???
2.  Will I want a camera installed on the back to help me park in some hidden dream location???
3.   Will I need some kind of a anti-sway hitch???
4.   What kind of mods should we consider right away???
5.   I’d like a generator that will handle the AC. What size do I need? I don’t need one for the whole camper, just the AC when it’s just so hot and humid.
6.  And what do I name it??? Now that’s a major problem!
So thanks for letting us be part of the rpod community. Please be patient with us as we learn the process of this forum. But please make any suggestions that you think we may need .
Now we’re ready for some PPP!!!
...On the road again! Just can’t wait to get on the road again....
Posted By: offgrid
Date Posted: 01 Apr 2019 at 7:27am
Welcome!
On your questions:
1) Personal choice. If not a topper then a stable stepladder and something to brush leaves and debris off the top of the slide.
2) Personal choice. If there are two of you then its not really needed for backing. rpods are a lot easier to maneuver than a big old 5th wheel.
3) Start by loading and actually weighing your trailer and tongue under real world conditions. If you're going to be boondocking then fill your gray tank which is aft and empty your fresh tank. That will give you your minimum tongue weight, which you should always keep above around 10% to avoid sway tendency. Beyond that what you get will depend on your tow vehicle. If its a lighter TV then you'll probably want a weight distribution/antisway hitch. If its heavier then maybe an electronic antisway system.
4) rpods come well equipped so you can wait till you've used the trailer a couple of times and see what changes you'd like to make before doing a bunch of mods. The only one I'd suggest doing right away is dual batteries if you're going to be camping much without hookups. Instead of the dealer installing a single 12V battery which is typical, you can have him install dual 6V golf cart ones.
5) First question is, where are you going to be camping using a generatior for the a/c? If its in park campgrounds there are usually noise restrictions that will keep you from running the generator all night on those hot sticky southeast nights. If you're truly boondocking in a remote location you can run the genny without bothering anyone, otherwise its daytime and early evening only. It's good to be realistic about generator use. Living in the southeast I find I rarely use mine for air conditioning because I'll either have hookups or go somewhere with cooler nights in the mountains in midsummer. The only true boondocking locations I camp in are in the mountains anyway.
There are three ways to go with generators and the a/c. You can get a larger generator, around 3500-4000 watts, that will start and run the a/c directly. But that is going to be about 100lbs, so could be an invitation to lumbar disc surgery. You can get two smaller generators, each around 2.2kw and 50lbs, and run them in parallel. Or, you can get one of these smaller generators and add an Easystart to the a/c so it will start from the small genny. If you go this route you will need to avoid running any other 120Vac loads in the trailer while the a/c is running.
6) I'm sure you'll get an inspiration once you get your trailer, if not before.
Enjoy!
Date Posted: 01 Apr 2019 at 8:11am
Thanks for your suggestions!
As for the slide topper. I believe right up front we will bite the bullet and have it installed. As for the sway issue my concern is making sure that I distribute the weigh for traveling. I am still using my truck that pulled our 5th wheel so I can handle the tongue weight. The 195 has a larger fridge and kitchen located on the back end. So I do get a little concerned about the tongue getting to light...
I like the idea about the dual battery upgrade.   As for a generator maybe I can do a mod to have one installed on the tongue??? šŸ’” plus that may help my concerns of keeping a good tongue weight šŸ¤”.
Again. Thanks for your input.
Posted By: offgrid
Date Posted: 01 Apr 2019 at 9:50am
Not so sure about mounting a genny on the tongue. I think some have done that on the forum, maybe they might have some comments.
 I'd suggest loading up and weighing the 195 and its tongue before adding a lot more weight from a genny up there. The dual batteries will add well over 120 lbs.  For that weighing you'd want the fresh tank filled and the gray tank empty. You don't want too much tongue weight, you might want to get a lighter tow vehicle someday. And you'd likely have to stack the generator on top of the batteries which might require some a-frame reinforcement, that's a lot of weight at one point load.
Also, you might get quite a bit of vibration, noise, exhaust fumes from the genny in that location. The inverter-generators are quiet when idling but when loaded up running the a/c they're pretty loud. I always try to move my genny as far away from my campsite (and my neighbors') as possible and point the exhaust away from everyone. Just trying to follow good campground etiquette....
Posted By: lostagain
Date Posted: 01 Apr 2019 at 9:59am
There is also the danger of carbon monoxide entering the trailer if you run the generator too close to the trailer, such as when on the tongue.  Most generator instructions warn users not to run the motor near enclosed occupied spaces.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Posted By: offgrid
Date Posted: 01 Apr 2019 at 10:17am
I think there's also a restriction in the RV code about distance between heat sources like a genny exhaust and the propane tanks. I don't recall what that distance is ATM.
Date Posted: 01 Apr 2019 at 10:45am
So much for the generator idea🄓. I’m glad I asked. I don’t want the fumes or the vibration. Probably check into something I can pull out of the truck when needed. Thanks again.
Posted By: offgrid
Date Posted: 01 Apr 2019 at 11:23am
Maybe you could just leave it in the truck bed and run it from there?
Date Posted: 01 Apr 2019 at 2:04pm
That’s what I was thinking. Thanks
Posted By: crw8sr
Date Posted: 01 Apr 2019 at 4:36pm
Welcome!  Get out there and enjoy it; mods and a name will follow.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Date Posted: 01 Apr 2019 at 5:49pm
Perhaps you should do a little research on the naming of boats for guidance.  There is a lore and superstitions that should be carefully followed.  After all an r-Pod is just a boat with wheels.
Sonoma 167RB
Our Pod 172
Date Posted: 01 Apr 2019 at 8:00pm
I know you’re right. But all I can think about at this time is pods. My wife and I are like two peas in a pod. It’s like everything in our lives have come to a stop because of this. So I would have to say, we have the rpod virus really bad.
Date Posted: 01 Apr 2019 at 8:03pm
Maybe this is another part of the old movie of ā€œInvasion Of The Body Snatchers ā€œ. Just the pods are a lot better. Shocked
Posted By: offgrid
Date Posted: 02 Apr 2019 at 1:17am
Depends which version of Invasion of the Body Snatchers you're referring to.
If you're talking about the original 1956 movie with Kevin McCarthy as Dr. Bennell you could name your pod the Santa Mira (after the fictional SOCAL town in the movie).
If you're talking about the 1978 remake with Donald Sutherland maybe you could call it the Space Flower, which is the form in which the pod aliens first appeared.
I love both movies, they perfectly reflect conspiracy theory paranoia. Anyone up for some fake moon landings LOL?
Posted By: Live2Camp
Date Posted: 02 Apr 2019 at 1:37pm
Welcome and congratulations! I agree with the comment to have a few trips or more before you do non-essential mods (two batteries asap - yes - very useful). Otherwise, my advice is to always carry drinking water in your tow vehicle regardless of how much you have in your Pod. That way you have it whether or not your trailer system works or has hiccups. Very excited for you, you are going to have so much fun! We love ours so much we often camp in it at home in between trips. Well and for that matter, if you are able to park your RPod at your home it's a great place to do your first shake-down trip/s.
2017 R-Pod 179 HRE (the green one)
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
Date Posted: 02 Apr 2019 at 2:59pm
Thanks. We are glad because we will have a location to park it at the house. Thanks for the advice. Now we just have to deal with the 24/7 anticipation of waiting.
Date Posted: 02 Apr 2019 at 6:07pm
Our Pod is our guest house when we're not traveling.  If we were rich, we'd call it the servants' quarters, but we can't afford servants.
Sonoma 167RB
Our Pod 172
Posted By: Dirt Sifter
Date Posted: 02 Apr 2019 at 8:48pm
That 195 is sweet! We have a 179 and love it after the 30' TT. Can't add much to others beyond setting the genny on the ground a ways from your house. We use a Honda 2000 with another to throw in when temps get too high. We also always carry a flat of bottled water in the TV along with a couple MRE's.
Congratulations on your R-Pod. It opens up so many more options, as you have figured out. :-)
Date Posted: 02 Apr 2019 at 9:21pm
Yes. We plan on using it as our guest house as well.  You have to let us know what your guest have said about staying in a pod.
Date Posted: 02 Apr 2019 at 9:35pm
How do you like those generators? If you had to start over would you buy them again?
Thanks for the congratulations,  we are truly excited.
Date Posted: 02 Apr 2019 at 10:02pm
We like'em. Start every time, run quietly and seem to be efficient. Take care of our needs. Others say that newer models of other brands are less expensive and just as good. Look around, you have time; research is your friend.
Greg n Deb 2020 195 HRE
Posted By: offgrid
Date Posted: 02 Apr 2019 at 11:48pm
I love my Honda 2K inverter generator. Converted it to dual fuel and only run it on propane. . No stinky gas or clogged carbs. Super reilable, I use it as my home backup generator as well, also on propane. Its light to carry, relatively quiet, and easy to start. And it runs the a/c fine with a Microair easystart installed.
The only problem is that I can't run it (or any genny) to operate the a/c at night when I need it in most campgrounds due to quiet hours. Only a big lithium battery pack and a big inverter will help with that problem.
Posted By: GlueGuy
Date Posted: 03 Apr 2019 at 8:44am
Of course, you can always install a big enough battery pack to entirely eliminate the generator like https://newatlas.com/tuscany-generator-free-motorhome-concept/59029/ - Thor did with their new Tuscany Lithium .
The key takeaway from that article is "Thor mentions more than once that certain features are what you'd expect from a seven-figure motorhome".
With a MSRP like that, the price of an R-pod is like a rounding error... Confused
Date Posted: 03 Apr 2019 at 8:59am
😲 WOW!  That’s why the rpod will also serve as our guest house. I would have to hire a full time caretaker for that. Plus work nights to pay for the insurance. I appreciate your suggestions though. I’m going to just neatly place that one in my round filing container. 😬
Date Posted: 03 Apr 2019 at 9:06am
If you go to the link Glue Guy posted, off to the side is an ad for a pod looking trailer that expands.  Talk about a slide out:   http://newatlas.com/beauer-3x-plus-camping-trailer/58343/ - https://newatlas.com/beauer-3x-plus-camping-trailer/58343/   That thing extends to nearly three times its original footprint.
Sonoma 167RB
Our Pod 172
Posted By: offgrid
Date Posted: 03 Apr 2019 at 12:49pm
Not being made of money or wanting to own a zillion dollar RV, I think I can have a/c overnight in my 179 for about $4K total cost.  That would include enough solar capacity to recharge on a sunny day, plus tow vehicle charging for cloudy days and any daytime a/c use (in the southeast we're mostly outside in the daytime, its at night we really want the a/c to sleep comfortably).   Not bargain basement cost but not bad for the additional capabilities for the kind of camping we do.
Date Posted: 03 Apr 2019 at 12:52pm
So what kind of setup are you using ?
Posted By: offgrid
Date Posted: 03 Apr 2019 at 1:25pm
I'm currently still just on the standard dual golfcart battery setup. The upgrade plan would include the following steps:
remove roof air and replace with high efficiency minisplit (twice the efficiency) (about $1000), condenser goes on the A frame and the evaporator goes above the bed.
remove the golf cart batteries and replace with a 5.2kw 24V Lithium pack salvaged from a wrecked Tesla, readily available from multiple sources (located under the bed) (about ($1300)
add a 2kw 24V to 120V sine wave inverter to run the a/c (about $400)
add 1kw solar to the rpod roof (now that the a/c is gone) (about $500)
add an MPPT solar charge controller (about $200)
add a 24 to 12 dc/dc converter and a small 12V battery to run the 12V trailer loads (about $200)
add two 12 to 24Vdc dc/dc converters to recharge the Tesla battery from my tow vehicle (about $500).
Yep, major surgery is required but it should be a fun geeky project. Geek
Date Posted: 03 Apr 2019 at 9:39pm
Wow. Now that sounds awesome. I will be honest, where I’m at in the rpod indoctrination.  You literally made my head swin. I’m still taking baby steps. I just now started to spell generator correctly (thank goodness for spell check).
What your talking about is not just major surgery. Sounds more like a heart transplant.
Posted By: offgrid
Date Posted: 03 Apr 2019 at 10:56pm
Its not as bad as it might sound at first, but I fully admit I'm a solar and dc power nerd.  I did this kind of stuff professionally for nearly forty yearsGeek. But, I'm far from being the first in the RV world either, most of what I've got in mind has been done before, check this out for example:
https://www.mortonsonthemove.com/toms-tech-blog - https://www.mortonsonthemove.com/toms-tech-blog
Date Posted: 04 Apr 2019 at 8:04am
Continue to take baby steps and keep it simple.  As time goes on and you become familiar with the Pod, you may want more and more challenges in making changes or modifications to it.  Each person has his/her own style, preferences and technical knowledge and that is reflected in the mods s/he does.  Some really enjoy putting in, what seem to me, very complicated systems the challenge of which they thoroughly enjoy.  Others, like me, like to see how we can accomplish similar goals while keeping the system as simple as possible.
Go slowly, drive slowly, enjoy using your pod and in time, you'll find your comfort level.
Sonoma 167RB
Our Pod 172
Posted By: crw8sr
Date Posted: 04 Apr 2019 at 5:02pm
Agree with lostagain.  Take it easy and enjoy the journey.
Chuck & Lyn
Izzy, Morkie. RIP
2018 R Pod 190
2019 Traverse
Date Posted: 04 Apr 2019 at 5:10pm
I definitely will take it slower paced. As they say ā€œone step at a timeā€.
I have to admit it has been awesome how the forum allows input from every angle. Then each of us picks the path we want to take.
Posted By: GlueGuy
Date Posted: 04 Apr 2019 at 6:07pm
Like the others. One step at a time. You yourself are not going to know what you really want or need until you've experienced a little podding. We took ours on a couple of short, nearby trips just to get a feel for things.
Posted By: offgrid
Date Posted: 04 Apr 2019 at 6:20pm
Which brings us full circle: other than possibly the dual battery install (which it sounds like you know you need and cam probably save $ if you have your dealer do it now) get out there and camp. You will quickly discover things that are fine as is and things that you wnat to change.
Have fun!
Posted By: Motor7
Date Posted: 07 Apr 2019 at 7:31pm
Don't forget, or maybe remember the comfort of a fan blowing directly on you while sleeping. My grandparents in Jonesboro Arkansas had no a/c. When we visited in the late 60's and early 70's it was always in the summer. Every room had a ceiling fan, every bedroom had a nightstand fan and I remember sleeping under a sheet and being a bit chilly in August. That fan that oscillated from bed to bed was a lifesaver(and I still have it...a Hunter Zeph-Air and yes it still runs perfect).
The requirements to run a fan or two all night are vastly different from running a/c. A two 6v battery bank and a large solar panel or two medium one's will keep you comfortable. Heck, you are 'camping' so giving up a/c for a trip is not the end of the world ;)
2016 R-Pod 176T
