Note of caution - propane tanks stolen!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12611
Printed Date: 13 Jul 2025 at 5:06am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Note of caution - propane tanks stolen!
Posted By: Ben Herman
Subject: Note of caution - propane tanks stolen!
Date Posted: 26 Feb 2019 at 5:57pm
Just a note of caution to fellow podders. I park my trailer in the driveway off of the alley in back of our house. Sometime in the past week, both of our tanks were stolen. I had a cable lock on them and they were covered. So if your pod is in a public place, either put a stout lock on your tanks or bring them inside the trailer over the winter. I have security lights and live in a decent downtown neighborhood, guess it was a crime of opportunity for someone looking to up their bbq game.
Pisses me off - two new tanks, both filled towards the end of last season. New cover on the tanks, with a trailer cover over everything. Now if I can only figure out how to rig up some of those ink-spraying anti-theft devices they have in retail stores nowadays, in case someone tries it again.
Posted By: StephenH
Date Posted: 26 Feb 2019 at 7:01pm
I'm sorry to hear about some low-life stealing your propane tanks. Cable locks are not that secure. We only have a single tank, but we also have it parked right in front of our house in our driveway. I carry a spare tank separately in the back of our pickup when we travel.
I did see this lock that looks to be better than a cable lock: https://www.etrailer.com/RV-Locks/TorkLift/TLA7701.html - https://www.etrailer.com/RV-Locks/TorkLift/TLA7701.html
This is another alternative which would also probably work well: https://www.walmart.com/ip/Propane-Lock-Dual/322922219 - https://www.walmart.com/ip/Propane-Lock-Dual/322922219
It is currently out of stock. The same thing is available on Camping World's site, but at about twice the price.
------------- StephenH
Posted By: offgrid
Date Posted: 27 Feb 2019 at 4:28am
I haven't tried one but how about something like this?
https://padlocks4less.com/cable-alarm-lock/?gclid=Cj0KCQiAh9njBRCYARIsALJhQkG7p6N9RZzt-phM-3Bk_qfuQ9h4CAPHjek8IBh5X9T3Zc_e6pqNwh0aAskBEALw_wcB - https://padlocks4less.com/cable-alarm-lock/?gclid=Cj0KCQiAh9njBRCYARIsALJhQkG7p6N9RZzt-phM-3Bk_qfuQ9h4CAPHjek8IBh5X9T3Zc_e6pqNwh0aAskBEALw_wcB
------------- 1994 Chinook Concourse
Posted By: lostagain
Date Posted: 27 Feb 2019 at 6:33am
I use a length of 1/4 inch chain looped around the top of the propane tank and around my two golf cart batteries. It would take about 2 seconds to cut it with a bolt cutter. The only thing I can hope for is that it is a visual deterrent and slows a thief down because of having to thread the chain off the tank or batteries, another 2 sec. operation. What really protects us is that we keep our Pod in a side yard behind a gate at our house. When traveling, well, it's more dumb luck than anything.
I like that cable alarm in offgrid's link. I may try one.
Sorry you had your tanks stolen.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Date Posted: 27 Feb 2019 at 7:34am
Found this approach - I'm going to do this once I find a new wing nut (they took that too). Looks like a really secure system, no cable or chain to be cut.
https://www.youtube.com/watch?v=nM9CsRBzBxs - https://www.youtube.com/watch?v=nM9CsRBzBxs
Date Posted: 27 Feb 2019 at 9:16am
Thanks for posting the video. That's a great idea with double tanks.
Anything you can do to slow down a thief or make it more difficult for him/her, the better. And that would certainly slow down the thief. A determined thief with a bolt cutter could cut the lock, but it's more likely that s/he would go on to the next trailer before going to all that work.
Unfortunately, that works for dual tanks, but for single tanks that method is not possible.
Sonoma 167RB
Our Pod 172
Posted By: marwayne
Date Posted: 27 Feb 2019 at 11:02am
My belief still is if you can't see it ,it's not there.
https://postimg.cc/Mvjg8Jns">
https://postimg.cc/HJJy6zZ7">
https://postimages.org/">
------------- If you want something done right, do it yourself.
Posted By: offgrid
Date Posted: 27 Feb 2019 at 2:05pm
One of the requirements for fire safety (in the States anyway) is for the fire department to be able to get access to the cylinder valves in order to be able to shut them off, so its a fire code violation for RV's to have propane tanks behind a locked door or to have the valves blocked from turning in some way. There are ventilation requirements too. You might never get cited for it but I'm just sayin'....
Posted By: marwayne
Date Posted: 27 Feb 2019 at 2:27pm
There is a vent in the floor and on the roof
Posted By: offgrid
Date Posted: 27 Feb 2019 at 3:09pm
Good, the vents are both required by code and sensible.
FWIW, here's the specs for RV propane enclosures from NFPA 1192 (the RV fire code):
One of the vents is supposed to be at the extreme bottom of the enclosure and one within 12 inches of the top in the wall, don't ask me why the wall and not the roof. They don't need to be very large, each vent to be at least 1/2 square inch for every 7 lbs of propane. The enclosure must be vapor resistant to the inside of the RV. The door to the enclosure can't have any locks on it. Max number of cylinders is 3 but they can be up to 45 lbs propane each. They must be secured to withstand 8x their full weight. I didn't see any labeling requirements for the enclosures.
Posted By: mcarter
Date Posted: 27 Feb 2019 at 5:55pm
Cable locks only make you feel secure, thieves love them, that is the fastest and easiest lock to disable. Takes minimal effort to cut a cable.
------------- Mike Carter
Posted By: Tars Tarkas
Date Posted: 27 Feb 2019 at 7:32pm
Originally posted by mcarter
Cable locks only make you feel secure, thieves love them, that is the fastest and easiest lock to disable. Takes minimal effort to cut a cable. | Not disagreeing at all, well, it may depend on the chain, and the cable, but chains can be pretty easy to cut too. Anyway, I remember in the 70's a lot of people thought that cables were the ultimate in security.
TT
------------- 2010 176
FJ Cruiser
Posted By: TheBum
Date Posted: 28 Feb 2019 at 10:33am
Chains aren't really any better. A good set of bolt cutters will make short work of them.
------------- Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Date Posted: 28 Feb 2019 at 4:54pm
Here's the solution that I came up with. Simple to do, and I already had a high-quality carbide shank lock that fits. Won't stop a professional thief but anyone stealing $35 propane tanks is in the low-budget arena.
https://postimg.cc/0r0pGRLM">
