How do you fold the table?
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12390
Printed Date: 20 Aug 2025 at 5:42am
Topic: How do you fold the table?
Posted By: cgarb
Subject: How do you fold the table?
Date Posted: 05 Nov 2018 at 5:19pm
We have been trying to fold the table down to use the dinette as a bed, but I think you must need to be an engineer to do it! Can anyone advise us on how to do it?  Embarrassed It looks like there are a couple of hinges, one high and one lower, on each leg, but we couldn't make them move. Do we just need some lubricant and more muscle? It looks like they should bend inward, but they don't budge. Any advice?
Thanks!!!!
Carol
177 HRE rpod
2014 Honda Pilot
Posted By: tcj
Date Posted: 05 Nov 2018 at 5:41pm
If it is just a larger version of the one in our 180, Pull the knob that is under the top out with one hand and then pull the table top away from the wall.
2018 R-pod 180 Hood River Edition
Posted By: cgarb
Date Posted: 05 Nov 2018 at 5:51pm
Is yours attached to the wall? Ours is free standing. There is a pin or knob to pull out and a long spring attached to a bar underneath the table top. There doesn't seem to be anything to pull against to pull it away from the wall since it isn't attached.
Carol
177 HRE rpod
2014 Honda Pilot
Posted By: tcj
Date Posted: 05 Nov 2018 at 6:40pm
Okay that is the same as our 180.  It is not attached to the wall.  Pulling the knob releases the catch that holds the top up.  The top has to be pulled away from the wall to allow the hinges in the legs to fold.  The table will fold down real easy if you pull the top away from the wall while while keeping the feet of the legs from moving.  The table will fold down to the height of the bed, then slide it back in place up against the wall.
Posted By: tcj
Date Posted: 05 Nov 2018 at 7:12pm
We had the same difficulty figuring it out the first time too.  Here's some photos to show how the table folds down.
Posted By: cgarb
Date Posted: 05 Nov 2018 at 7:52pm
Thank you, all! That is an immense help! should be able to do it now. Seems like it should come with directions! They may have shown us how it works 7 years ago when we picked up the Pod, but who remembers back that far?!
Carol
177 HRE rpod
2014 Honda Pilot
