Table Improvement
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12340
Printed Date: 20 Aug 2025 at 11:33am
Topic: Table Improvement
Posted By: Kevinscamps
Subject: Table Improvement
Date Posted: 23 Oct 2018 at 11:53am
I got rid of the stupid Rpod table and built an attached table.  It is more solid and much easier to clean around and get into and out of.  I will make a nicer table top at some point, but this will do for the moment.  I can still transform it to a bed by knocking the pins out of the hinges, removing the top and folding the table leg down.  If we are using the dinette as a bed often (not the plan) I will get some metals pins which will be much easier to take out then the tapered pins of the door hinges.
 The pictures show the window in cold weather mode with reflectix installed.  The wooden support makes putting the reflectix under the window shade much easier and should block cold air falling down the wall.  The reason the support along the wall is so long is because there is nothing but styrofoam in the wall where you want the table to be.
Here is the link to the foldable leg support:
https://www.amazon.com/gp/product/B073B28XZG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Here is the link to the door hinges:
https://www.amazon.com/gp/product/B00OQVVFNU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Posted By: Woodmiester
Date Posted: 23 Oct 2018 at 12:05pm
I like it!Big smile
Swampfox
Posted By: Leo B
Date Posted: 23 Oct 2018 at 5:44pm
Nice Job!!
Posted By: crw8sr
Date Posted: 23 Oct 2018 at 6:24pm
Well done!
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Posted By: Cactus_Hawk
Date Posted: 29 Oct 2018 at 11:06am
 Here are my table mods. Decided to re-build the existing ottoman to incorporate a table.  Got the idea from coffee tables that have a lift up top.  The new ottoman is an inch shorter than the old one but about 6 inches wider.  It needed to be wider to hold the arms that allow it to move up in position.  I made the arms, table top,and box myself...as you can see, I’m not a steel worker or furniture maker:)I still need to make a new cushion for it.
Posted By: offgrid
Date Posted: 29 Oct 2018 at 11:53am
I like it. That's a 179 right? Did you remove the other ottoman?
I was just looking at that ottoman this morning. I'd like to mount an inverter in that unused space but its a bit too small. You've given me an idea...
Posted By: StephenH
Date Posted: 29 Oct 2018 at 12:59pm
Wow! That is spectacular! I like it!
I would like to see more details for sure, such as the arm mechanism inside the new ottoman and under the table.
I would be interested in reading how this performs in actual use also.
Date Posted: 29 Oct 2018 at 2:57pm
Yes, it’s a 179. I did remove the other ottoman as it just took up space.  To clarify we don’t ever plan on using the dinette as a bed other than just the bench seat.  Our son fits there just fine.
Date Posted: 29 Oct 2018 at 3:04pm
Here are some additional photos.  You can buy arms off of different places like Amazon but the tallest I could find was about 11” and I needed at least 18” in order to comfortably slide in under the table so I just made them myself.  Built a few prototypes out of cardboard first to make sure I understood the function and dimensions.  The new ottoman is just 2”x3”, 1”x1” and oak veneer plywood.
Posted By: offgrid
Date Posted: 29 Oct 2018 at 3:33pm
Very nice!
We never expect to have anyone sleep in that area.  My wife telecommutes sometimes though so it could be a nice compact workstation for her (if I make the extension leg removable) as well as a larger dining area when extended.
I can see replicating something very similar and at the same time building in my inverter and providing ventilation for it. Maybe also a slide in seat back for her to have back support working?  It also solves my problem of having to flip the current table upside down on the bed  so it doesn't slide around while towing on windy roads.
Were there any issues with having to repair the area where the other ottoman you removed was?
Thanks for sharing!
Date Posted: 29 Oct 2018 at 3:36pm
Originally posted by offgrid
Very nice!
Thanks for sharing!
No real repair needed as there are only three small holes where the old screws went into the floor.  Can’t even see them unless you know exactly where they were...and even then it’s hard to find them.
Posted By: offgrid
Date Posted: 29 Oct 2018 at 5:29pm
Great, thanks!
Posted By: StephenH
Date Posted: 29 Oct 2018 at 6:47pm
Very nice indeed! Do you have any sort of spring on the legs to help raise the table and/or keep it upright or does the lid to your new ottoman serve the purpose to keep it upright when it is in place?
Date Posted: 29 Oct 2018 at 8:01pm
I wanted to add springs but could not find ones that fit right (problem with my design). The good news is the lid to the ottoman holds the legs in place really tight so no real need. The springs would have helped with lifting the table into position but it’s not that heavy.
I made this on the fly and if I did it again I would make a few changes. Springs would be one and another type of wood would be another. Popular might have been a better choice to match the existing wood/fake wood. I found the stain color on this forum and it matches well but the grain of the oak not so much.
Posted By: StephenH
Date Posted: 30 Oct 2018 at 12:11am
One caveat on using Poplar for the top: It warps with changes in humidity! I made a table and will need to re-do the top as the boards warp. The one way I could fix it would be to cut the top into strips and reverse alternate ones, gluing them together with splines or biscuits to keep them from separating. That way, the tendency to warp would be mitigated by grain not all running in the same direction.
Posted By: GlueGuy
Date Posted: 30 Oct 2018 at 10:09am
Why not just use a decent veneer plywood? That would solve the warp issue, and you'd just have to trim the edges with a strip or matching veneer?
Like the idea very much BTW.
Posted By: StephenH
Date Posted: 30 Oct 2018 at 7:04pm
Plywood would be the easier way to go and I have been considering using it to replace the warped poplar top. I was thinking of using a thin trim strip around the edges which could be poplar or other wood, possibly contrasting. That way, I would not have the plywood veneer edges to look at. It could also be an angle strip and then it would make a rim around the edges. That would work on the outsides, but not the place where they come together. I would not want a ridge down the middle of the table when it is set up.
Right now, I can't do anything about it since the table is in our R-Pod at the dealer's service department. It will probably be at up to five more weeks before we get it back.
