New R-Pod 179 Owner
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12333
Printed Date: 22 May 2025 at 2:47am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: New R-Pod 179 Owner
Posted By: Djdave
Subject: New R-Pod 179 Owner
Date Posted: 21 Oct 2018 at 12:30pm
Just picked up a 2019 10th Anniversary Edition 179 at Keystone MegaRV Center, Greencastle, PA. Towing with a 2017 Jeep Cherokee Overland and dealer installed a Prodigy RF Brake Controller. First time buying at Keystone and I highly recommend and ask for Rebecca. Junior at Keystone does a ton of user video's on YouTube which are both educational and funny.
This is our 5th RV and we've camped in a pop-up, travel trailer, 4th Wheel and 43' Diesel Pusher. Getting older and decided to downsize.
Looking forward to camping our new Pod!
Dave
------------- Dave
2019 R-Pod 179 10th Anniversary Edition
Posted By: offgrid
Date Posted: 21 Oct 2018 at 4:24pm
Welcome Djdave. You'll enjoy your Pod and will get into a lot of places the diesel pusher couldn't. It looks though like the Cherokee Overland only has a 2000 lb tow rating, is that really right?
------------- 1994 Chinook Concourse
Posted By: mcarter
Date Posted: 21 Oct 2018 at 4:33pm
I don't think so, they have a Class III package and a HD package available, the III package is 6200 and their HD is 7200. Depends on the website you look at.
------------- Mike Carter
Posted By: offgrid
Date Posted: 21 Oct 2018 at 4:39pm
Yah, looks like there are both a Cherokee Overland and also a Grand Cherokee Overland, hopefully Djdave has the latter.
Posted By: StephenH
Date Posted: 21 Oct 2018 at 5:12pm
Welcome and Congratulations. We have not owned the variety of RVs you have, just our RP179. My wife and I have traveled a lot with it, most recently to the Kentucky MiniMini which was hosting the R-Pod 10th Anniversary Rally. I've done a number of modifications to ours, some of which might be useful to you (see link in signature). I hope you enjoy your R-Pod as much as we enjoy ours.
------------- StephenH
Posted By: Djdave
Date Posted: 21 Oct 2018 at 5:58pm
Hi Folks,
I was also concerned about the towing capacity but we can tow 4,500 pounds. By entering the VIN into the Mopar site, it provides a ton of information including the towing capacity which says 4,500 pounds. We have the Jeep Cherokee Overland 4 x 4 and not the Jeep Grand Cherokee although if I had to do it over again, we would have bought the Grand Cherokee. But we have a motorhome (which we still have and trying to sell), so I wasn't concerned about towing at the time when buying the Jeep. I had (and sold) a 2017 Jeep Wrangler Sport which I towed behind the MH.
The site also states that our Jeep has both an auxiliary transmission oil cooler and engine oil cooler. It lists the final drive ratio at 3.517 which from my research comes with the tow package. Also, verified the owner's manual and had the Jeep Dealer install a Class III hitch and wiring. The RV dealer installed a Equal-I-zer E2 weight distribution hitch and sway control although the Mopar site says that we have sway control on the Jeep but not sure what that means.
On the Jeep site here http://www-5.jeep.com/en/jeep-capabilities/towing/#Cherokee4Tab - http://www-5.jeep.com/en/jeep-capabilities/towing/#Cherokee4Tab we have the Pentastar 3.2L V6 24V VVT with ESS which was verified on the Mopar site for our specific Jeep. The Jeep Grand Cherokee Overland has a little more horsepower and torque with a max towing of 6,200.
Having towed a travel trailer and 5th Wheel, the later with a 2008 Ford F450, I'm very sensitive to vehicle towing capacity although with the F450 I could tow a wide range of RV's. The last thing that I want to do is to tow unsafely and put both my wife and I and others in a dangerous situation.
Thanks! Dave
------------- Dave
Posted By: Djdave
Date Posted: 21 Oct 2018 at 6:01pm
Thanks Stephen!
I reviewed all of your mod's and you are very talented! Not sure I could tackle the ones you have done. The only mod I'm going to do is to add a flexible solar panel and controller. It's already wired for a solar panel with the connections on the roof and a place for the controller. Checking the battery, there is two black and red wires, so I'm assuming one set is run up into the POD right where I can install the controller.
Thanks for the post!
Dave
------------- Dave
Posted By: offgrid
Date Posted: 21 Oct 2018 at 8:24pm
Djdave, glad to hear you have 4500 lbs capacity, but that is still pretty close depending on how you load the trailer and the tow vehicle. Its surprising how quickly the weight builds up, as I'm sure you know from experience with your other RV's.
My 179 goes out at about 3900 lbs with about 570 tongue weight, with dual batteries, single propane, and a full fresh water tank. I have a Toyota Highlander with a 5000 lb tow rating and wd hitch. I carry basically nothing but my wife and I in the tow vehicle and I'm comfortable towing but really wouldn't want to push it any further.
If you haven't already, you should also check the gross combined vehicle weight and individual axle loads. You can use a commercial scale to get the actual weights the way you plan to load. Here is a nice calculator that takes into account the effects of the wd hitch.
https://www.ajdesigner.com/apptrailertow/weightdistributionhitch.php
Not sure where they're expecting you to put the solar charge controller in the new pods, but you can connect to the battery conductors anywhere and it will work fine. Best to install a fuse though if they don't already provide for one.
Posted By: StephenH
Date Posted: 21 Oct 2018 at 8:28pm
To tell you the truth, I did not think I could have done some of them myself. I have learned a lot by doing (with the help of Google and YouTube). That is also why there are version 2 of some mods.
Posted By: Live2Camp
Date Posted: 21 Oct 2018 at 8:48pm
Welcome! We love our 179, and really enjoy and appreciate this forum. I'm betting you will too.
------------- 2017 R-Pod 179 HRE (the green one)
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
Posted By: Leo B
Date Posted: 22 Oct 2018 at 5:56pm
Welcome to the group!
------------- Leo & Melissa Bachand
Posted By: Djdave
Date Posted: 24 Oct 2018 at 5:58pm
Thanks for the advice and link. After talking it over with the wife, we are thinking about getting a truck to pull the RPOD. Still in the research phase but probably going to get another diesel. Sure, it will be overkill for the POD but you only live once!
------------- Dave
Posted By: offgrid
Date Posted: 24 Oct 2018 at 6:18pm
Djdave, I agree and think you'll be more comfortable towing with a truck. You obviously have a lot of experience RV'ing with larger rigs so it will feel more like what you're used to. A halt ton with a tow package will do a great job for you. But off course, you could always go bigger too
Posted By: Djdave
Date Posted: 24 Oct 2018 at 7:24pm
Off grid, I got spoiled when I had the Ford F450 and a 11000 pound 5th wheel. Hardly knew it was back there. We have our eye on a 2016 Nissan Titan XD Platinum Reserve with 5.0 Cummins Diesel with a tow capacity of over 11000 pounds. I think that should be sufficient to pull the POD!
it’s a beautiful looking truck and the price is about right. Trying to get the dealer to come down even more. Waiting to get closer to the end of the month to see if they wheel and deal.
And the best thing is that my wife likes the truck too and has approved the purchase!
------------- Dave
Posted By: offgrid
Date Posted: 25 Oct 2018 at 4:26am
Yeah with an F450 I guess you can pretty much tow anything anywhere without worrying about it... The Nissan sounds like you should be able to do the same, just more pod sized. Cummins makes a great engine.
In my case, I don't want to have a dedicated tow vehicle. Living on the OBX at 3 ft above sea level the less stuff that you own that can rust and that you have to find some high ground to park during storms the better off you are.
So I wound up with the Highlander as about the lightest vehicle for towing a 179 that I felt comfortable with but the biggest car my wife felt comfortable with as a daily driver. I do have to watch the weights in the trailer and the Highlander but its not so maxed out that it makes me feel uncomfortable on the road. If I had kids or other heavy gear I wanted to haul on trips then that would be a different story.
Posted By: Djdave
Date Posted: 26 Oct 2018 at 3:32pm
StephenH.
I was going through the pictures of tow vehicles and several years ago, you said that you were towing with a 2014 Ford Escape with Ecoboost. Do you still have it and how does it tow? I looked up the tow ratings and it's at 3,500.
As I've stated in my post, we are towing with a 2017 Jeep Cherokee Overland with a max towing of 4,500. I'm a little concerned that after my wife and I get in the car and we load up the POD, we are getting close to about 3,700. I do need to weight it and we do have a WD bar.
Thanks! Dave
------------- Dave
Posted By: StephenH
Date Posted: 26 Oct 2018 at 3:45pm
Actually, it was a 2016 Escape. We had an accident where we hit ice with a strong cross-wind in Wyoming. We had to purchase a replacement vehicle to get us and our R-Pod home. After the Escape was repaired, we sold it to CarMax (took a huge hit in depreciation loss, but since we were paying much more than needed, we got enough to pay off the loan). It performed well. The shorter distance between the center of the rear axle to the hitch ball meant that the trailer exerted less force on the Escape than we feel with the Frontier which has two more feet between the axle and tow ball than the Escape had. I'm not of the school that the tow vehicle has to be longer than the trailer. After all, look at tractor-trailer rigs going down the road. The trailers are much longer than the cabs on those. It is actually advantageous when backing to have a longer trailer than tow vehicle.
More towing capacity would be nice, but you should be okay with your Jeep Cherokee Overland. If it is front wheel drive, you will absolutely need a weight distribution hitch to make sure you have sufficient force on your front wheels. If it is rear wheel drive, you are okay. If it is 4 wheel drive, even better.
Posted By: offgrid
Date Posted: 26 Oct 2018 at 5:59pm
It would take a couple of hours but the way to know for sure is to load up the Cherokee as you plan to, put the wd hitch on it and take it over a public scale without the pod. Get weights on the front axle by itself and then on both axles so you also know the rear axle weight (total - front axle = rear axle). Then go get the pod (fully loaded also) and run over the scale axle by axle again to get all three axle weights (wd hitch should NOT be tensioned for this). The tongue weight will be the difference between the tow vehicle with and without the trailer (as long as the wd hitch is not tensioned). Then put all the actual measured axle weights, dimensions and the weight limits (gcvwr, each tow vehicle max axle wt, tongue wt, trailer gvwr, and trailer max axle wt) in the towing calculator. Then add tension to the wd hitch in the calculator until the front axle is back to the weight it was without the trailer. See if that brings everything within specs with a reasonable safety reserve. If it does, tension the wd hitch until the height of the front fenders is the same as without the pod and camp on!
I did this and ended up leaving some gear out of the Highlander and then feeling fine towing knowing all is good with my tow vehicle. I found though that with my normal load and the wd hitch tensioned that the trailer axle (3500 lbs max) is pretty close to its limits. So I'm buying higher capacity tires and 15 inch wheels for it. Some folks don't think the wd hitch increases the trailer axle load, but it for sure does.
Posted By: Djdave
Date Posted: 26 Oct 2018 at 7:02pm
Offgrid - thanks for the post and instructions on how to weight. To best honest, with the F450, I never worried about it for obvious reasons.
Although I thought I did the research on the Cherokee, I think you are right in that actual weights are the only way to get a true picture. I also appreciate the link to the site to enter the weights. That will really help!
But, if I'm able to buy the Nissan Titan XD Diesel, I'm certainly not going to worry about it!
Dave
------------- Dave
Posted By: offgrid
Date Posted: 27 Oct 2018 at 2:38am
Yes, to be sure, having a tow vehicle large enough to not have to worry about it is easier. But after you've done the weighing process one time and you know what you have you'll never have to do it again, at least not until you decide to do some major mods
If you've already decided to get the Nissan then of course don't bother but if you're on the fence I think after doing the weight checks you will know what to do, either you'll be feeling more comfortable with the Cherokee or less.
Posted By: offgrid
Date Posted: 27 Oct 2018 at 8:12am
Djdave, i'm not trying to be negative about the Cherokee but one other consideration for you is the size of the fuel tank. The guy I bought my 179 from originally towed it with a Rav4 which had about a 16 gallon tank. Since no matter what you tow with you'll at best get about 14 mpg, to have a reasonable fuel reserve he was looking for a gas station every 120 miles or so which drove him crazy. My Highlander with the same drivetrain and same 14 mpg fuel economy towing has about a 20 gallon tank so I can go about 180 miles before getting fuel, by which time I want to stop anyway. You wouldn't think so but just that additional 4 gallons makes a big difference in useful range.
Posted By: GlueGuy
Date Posted: 27 Oct 2018 at 10:49am
We love our 36 gallon tank! Even at 14 MPG we can go over 400 miles. That's usually longer than our bladders last.
------------- bp
Posted By: StephenH
Date Posted: 27 Oct 2018 at 10:59am
+1 on the fuel tank capacity. Our Escape was the same way. About every 100 miles, I was checking GasBuddy.
Posted By: offgrid
Date Posted: 27 Oct 2018 at 11:20am
400 miles is usually longer than your bladder lasts GlueGuy? That's what, about 6 hours drive time? My bladder hasn't lasted that long in decades, if ever . I'm OK with 180-200 miles with reserve, at 3 hours that about syncs my bladder up with the fuel tank size. But 100-120 miles would drive me crazy, there are quite a few places where gas stations are 50 plus miles apart so it adds unneeded stress to what should otherwise be a pleasant road trip.
Posted By: GlueGuy
Date Posted: 27 Oct 2018 at 12:34pm
Originally posted by offgrid
400 miles is usually longer than your bladder lasts GlueGuy? That's what, about 6 hours drive time? My bladder hasn't lasted that long in decades, if ever . I'm OK with 180-200 miles with reserve, at 3 hours that about syncs my bladder up with the fuel tank size. But 100-120 miles would drive me crazy, there are quite a few places where gas stations are 50 plus miles apart so it adds unneeded stress to what should otherwise be a pleasant road trip. | When I was younger, I could go 24 hours. Haven't been that way for a while though. 4-6 hours is typical for me. But you know, separate from the bladder issue is just sitting on your butt too long. A leg-stretching break every couple of hours is about right.
------------- bp
Posted By: offgrid
Date Posted: 27 Oct 2018 at 2:54pm
When I was in my 40's and owned an airplane I would often do 5 hour legs (by myself). My wife couldn't, three was about her limit. Now I've caught up with her. The prostate rules in the end....
Posted By: crw8sr
Date Posted: 29 Oct 2018 at 8:48am
Nice pun Offgrid!
------------- Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Posted By: offgrid
Date Posted: 29 Oct 2018 at 8:58am
Hee Hee
Posted By: lostagain
Date Posted: 29 Oct 2018 at 9:21am
I learned a trick from a fighter pilot who flew in WWII. He was partner emeritus in our firm and flew us all over CA in his little Cessna 152 tail dragger. It applies only to men: Carry a milk carton for emergencies. Quarts work best.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Posted By: offgrid
Date Posted: 29 Oct 2018 at 9:40am
A suggestion if you use that solution: drink the milk FIRST.
For the ladies there's this:
https://www.sportys.com/pilotshop/lady-j-adapter-for-little-john-pilot-urinal.html?utm_source=google_shopping&m=simple&mrkgcl=596&mrkgadid=3298321377&utm_medium=cpc&utm_campaign=Safety+%26+Survival&adpos=1o1&creative=295428069994&device=c&matchtype=&network=g&gclid=CjwKCAjw39reBRBJEiwAO1m0ORbdMovb3h70cz_d2a-q7cam60lD9S87qwJ0fgWluwAG6cBwk2bE0BoCEh8QAvD_BwE
Did he have the rare long range tanks in that 152? If not its only got about 3 hours useable fuel. Same as my Highlander.
Date Posted: 29 Oct 2018 at 10:21am
No, he had no extra fuel tanks or longer range. He was in his late 70's at the time and 3 hours with coffee is a long time.
Re milk in the carton: Please note I did not say bring a carton of milk; only the milk carton.  The newer plastic milk bottles don't work so well.
Sonoma 167RB
Our Pod 172
Posted By: GlueGuy
Date Posted: 29 Oct 2018 at 10:46am
I had mine equipped with relief tubes. Look out below!
------------- bp
Posted By: offgrid
Date Posted: 29 Oct 2018 at 11:04am
Better than getting hit in the head by blue ice from a commercial jet...
Date Posted: 29 Oct 2018 at 12:12pm
Glue Guy, that's what I yelled from the top of the mast of a sail boat after struggling to free the jib sail for a half hour and lost my cookies. In a rolling sea, there's quite a bit of travel from one end of the arc to the other. Not a single cookie crumb hit the deck.
Sonoma 167RB
Our Pod 172
Posted By: Djdave
Date Posted: 04 Nov 2018 at 6:48pm
After spending hours upon hours researching, reviewing, and test driving vehicles, we decided our new TV is a 2014 Tundra 2WD SR5 Crewmax 5.7L V8 DOHC 32V. Max towing is 10,100 so we have plenty of truck. Buying from a private seller and everything has checked out i.e. VIN check, Carfax, etc. It's silver and will complement our 10th Anniversary grey-colored 179.
Just wasn't feeling comfortable with the prospect of towing it on long trips with the DW's Jeep Cherokee even with the 4,500 pound towing capacity. Was initially leaning towards a Nissan Titan XD Diesel but I feel comfortable with the Tundra and especially since it uses regular gas!
Will post a picture when I get it.
Dave
------------- Dave
Posted By: GlueGuy
Date Posted: 04 Nov 2018 at 7:03pm
Congrats on the truck. We had a 2005 Tundra once upon a time (also silver), and it was a great truck. Whenever we looked/shopped/compared, we always seemed to get the better deals from the Toyota dealer than the Nissan dealer across the street.
------------- bp
Posted By: offgrid
Date Posted: 05 Nov 2018 at 4:49am
Tundras are great trucks. Not knocking Nissans but Toyota consistently gets top reliability ratings. Toyotas hold up well and hold their value well. I bought a used 2012 Highlander to tow with, just didn't want another truck. It's working out great.
Lots of folks buy diesels because they think they will be getting better fuel economy and then find out that because of the higher cost of diesel they're not. The newer diesel pollution controls have issues too. I think you'll be happy with your choice.
Posted By: crankster78
Date Posted: 05 Nov 2018 at 9:04am
Greetings:
I've found the 179 to be a very good floorplan for 1 or 2. Being older, I made a box step to make it easier to get into the bathroom. May you enjoy your pod as much as I enjoy mine.
Crankster78 R-179 2015
------------- Crankster 78 R-179 2015
Posted By: Djdave
Date Posted: 05 Nov 2018 at 7:39pm
offgrid, first time I've owned a Toyota truck. I've had two Fords (F-150 and F-450) and then a Chevy Silverado. Thought that if I got a Diesel, it would last a long time. But the way I go through vehicles, the gas engine works just as well and easier to take care of. I was impressed with the 10,000 pound towing capacity for the $$ I'm paying. Hopefully, I'll keep this truck longer than the others.
Still have the DW's Jeep (now with a hitch) and my daily driver is a 2012 Caddy CTS. I work in downtown Washington, DC and park in a garage, so the Caddy works just fine as a daily driver.
Dave
------------- Dave
Posted By: Djdave
Date Posted: 05 Nov 2018 at 7:44pm
Crankster, thanks and the DW really like the bigger kitchen in the 179 along with the storage. Great idea on the box step as that's a big step into the bathroom. Got a toilet light from Amazon http://a.co/d/eXTd0Wj%20 - http://a.co/d/eXTd0Wj so I won't have to turn on the light and wake up the DW. Haven't tried it yet and saw someone on the R-Pod Facebook group use one so I figured it was worth the try.
We picked up the 179 from the dealer but couldn't camp in it because its starting to get colder. Can't wait until March to get up and running.
Enjoy!
------------- Dave
