Rear leveling jacks too low!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12327
Printed Date: 20 Aug 2025 at 9:02am
Topic: Rear leveling jacks too low!
Posted By: Rsexypod
Subject: Rear leveling jacks too low!
Date Posted: 19 Oct 2018 at 11:25pm
The first day when I picked up my barely used 2016 RP 178, I was pulling out of the parking lot at the bank and heard that terrible sound! The leveling jacks scraped deep into the asphalt. I got home and checked it out, found that both jacks had been replaced. I saw a couple of the original screws snapped off in their holes. The pod only had 3 trips on it!
So I removed both rear jacks, had my muffler guy weld a u shaped bracket the same size as the frame.  Also had 2 12” strips of steel welded to the frame, I didn’t like the multiple holes left by the self tapping screws. Then I drilled a hole all the way  thru the bracket and frame and installed a clip pin like you have on a hitch. This way the jack can’t slide out on uneven terrain. Gained 5” of clearance.
On our second trip out, we had a steep site to back into at Diamond lake. Really meant for tent camping.
The only thing that scraped was the spare. Since My tow vehicle is a pick up with a shell, I just carry the spare in the back of the truck now. If I had an SUV tow vehicle, would opt for the hitch mount spare carrier, and counter the weight by adding more stuff to the rear storage.
Posted By: Tars Tarkas
Date Posted: 20 Oct 2018 at 2:12am
Check the level of your Pod, front to back.  You can raise the back by lowering your hitch an inch or two or more, if that won't make you too low on the front.
TT
FJ Cruiser
Posted By: Wood River Pod
Date Posted: 20 Oct 2018 at 9:58am
We have a steep driveway.  Before we raised our 179, we added the SaveAJack on the back of the pod.  Easy in and out after that.
http://stores.saveajack.com/ - http://stores.saveajack.com/
Highly recommend.
Thanks
Smith's in Hailey
Early 2017 179 HRE
http://www.rpod-owners.com/forum_posts.asp?TID=9134&PN=1&title=wood-river-179-mods - Wood River Mods
Posted By: Awchief
Date Posted: 20 Oct 2018 at 10:23am
I added the FR 3 5/8 riser blocks. No more dragging my “stabilizer jacks”.
Michael
Posted By: mcarter
Date Posted: 20 Oct 2018 at 10:56am
My 2015 178 had the risers, I added save -a-jacks.
