Adding an awning to a Rdome ready POD
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12120
Printed Date: 26 Jun 2025 at 5:36am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Adding an awning to a Rdome ready POD
Posted By: schleygo
Subject: Adding an awning to a Rdome ready POD
Date Posted: 27 Aug 2018 at 12:29pm
Hello All
Still looking for a 180. Found a good used 180 that has the Rdome ready lining. Well, the better half hates the Rdome. We just want to pull into camp and open the awning in 30 seconds.
The question is not if.....but has anyone added an awning to a Rdome ready Rpod? We are look in g for a 180 length awning. Im thinking the used Rpod180 + an aftermarket awning would be cheaper than a newer one
------------- Hello!
Posted By: Keith-N-Dar
Date Posted: 27 Aug 2018 at 12:45pm
Forest River told me that the Tule awning could only be put on a Pod that had reinforcement built in at the factory for it. I don't know if all this year's pods are so prepared or if it has to be ordered with an awning.
------------- Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: mjlrpod
Date Posted: 27 Aug 2018 at 12:59pm
My dealer told me about a year ago, you cannot get a pod with both the awning and the dome. Like anything, that can change with the next run on new units, but at that time you couldn't.
------------- 2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted By: mcarter
Date Posted: 27 Aug 2018 at 3:49pm
The awning pods have a reinforced wall the dome pods don't. Not compatible.
------------- Mike Carter
Posted By: Happy Tripping
Date Posted: 27 Aug 2018 at 7:28pm
Originally posted by schleygo
Well, the better half hates the Rdome. We just want to pull into camp and open the awning in 30 seconds. The question is not if.....but has anyone added an awning to a Rdome ready Rpod? |
If you are an experienced RVer, ok, but if not, it may be a mistake to just write off the r-dome. It has it's drawbacks, like flimsiness, but it is much better than any awning in wind or rain or bug country, in my opinion.
That said, any big strong nylon tarp with grommets can be rigged to slide thru the keder rail of the r-pod with 'sail slugs' and it does the job of an awning quite well. Proper length tent poles and ropes attached to big tent stakes keep the outside corners anchored, I have whittled plugs that insert into the ends of the keder rail to keep the tarp anchored there with short lengths of nylon cord.
There are other solutions that you may be able to find using the extended 'search' mode of the forum (altho it's pretty pathetic).
Posted By: StephenH
Date Posted: 27 Aug 2018 at 10:36pm
For our style of travel, the awning makes much more sense than an R-Dome. We started out with an R-Dome ready 179, but when it went to the factory for repair, the side was replaced with the reinforced one and I was able to get a Thule awning added. I would not recommend that way of getting one though. Before we got the Thule awning, I had made an awning that slid into the track and used plastic poles for support along with concrete filled coffee cans with eye bolts for hold-down ropes. There are pictures in my mods of how I did that one. The hardest part was figuring out how to make brackets to hold the lower edge of the supports and then welding and bending them followed by some grinding the back so they would clear the screws in the lower track.
------------- StephenH
Posted By: podrunner
Date Posted: 28 Aug 2018 at 1:19am
martisawnings.com
We love ours....
------------- 2010 R Pod 151
2017 4runner
2006 Honda Metropolitan
Posted By: schleygo
Date Posted: 28 Aug 2018 at 4:30am
I didn't mean to start a rant. I just found a 180 at a price we can afford but it is prepped for an Rdome. Thank you all for the info. Everyone here is great. Thank you
Date Posted: 28 Aug 2018 at 6:44am
I didn't mean to start a rant. |
If you have questions re r-pods, this is the place for them.
Just the usual helpful submissions, no rants present.
------------- "There comes a time in the affairs of a man when he must take the bull by the tail and face the situation" - W.C. Fields
Posted By: furpod
Date Posted: 28 Aug 2018 at 7:23am
I didn't see any ranting. The dome isn't for everybody.. (I say that, in the moderator spirit, because everyone knows in their heart, the DOME is HOME!! )
The whole point of this group is discussion and help. If you ask a question, needing help.. you will get discussion.
Many owners have gone to a slide in, home made or purchased awning. You have to do what works for you. Many owners now have the CLAM, which, in some situations, is a better choice then a dome OR an awning, because it doesn't attach to the Pod..
Posted By: 4Papa
Date Posted: 28 Aug 2018 at 7:41am
I ordered a 180 with an awning and after arriving at the dealers to pick up the new pod, discovered the pod they prepped came instead with a dome. Bummed at first and after fumbling setting it up for the first time decided I can do without it. In the bag it stayed for the first season.
This season my wife talked me into trying it again and am glad she did. Not just double the space of the pod, but when most of our outings this season where graced with punishing T-storms, including wind and heavy rain, instead of retreating inside where it was either sweltering or ear-splitting from the AC, we were relaxed outside with cocktails protected by the surprisingly strong (when properly staked down) dome. Other campers had to scramble to retract their awnings... if they were lucky enough to be around when the winds came... otherwise what they returned to wasn’t pretty.
A side benefit is the near tent-like nature when the skirt is added. Our 13-year old daughter (too tall to fit the ridiculously narrow dinette/bed in the 180) prefers to sleep instead in the dome with its space, privacy and relative security from critters provided by the skirt.
So, I’m a convert. There are some improvements Dometic might make, like using beefier zippers and providing better stakes. Instructions on customizing the skirt to fit your particular camper would help (wheel wells and steps).
------------- 2017 180
2010 GMC 1500 Hybrid
Posted By: backin15
Date Posted: 03 Sep 2018 at 2:50pm
You can get a small awning from PahaQue, it mounts in the Rdome track and is easy to put up. A bonus is that it is very light and doesn't take much storage space. We love ours!
------------- 2015 179
2013 Xterra Pro 4X
Posted By: 4Papa
Date Posted: 03 Sep 2018 at 7:07pm
Posted By: 4Papa
Very cool. And the price is decent, too. Kind of hard to see what kind of coverage you get, though.
Posted By: backin15
Date Posted: 03 Sep 2018 at 8:45pm
Not a ton of shade, but keeps the chairs and shoes dry in the rain.
2013 Xterra Pro 4X
Posted By: Marchhall
Date Posted: 04 Sep 2018 at 4:00pm
RDome is why I bought the RPod. We only sleep in fiberglass box and all living done outside at Camp. More than doubles living space. Sure it takes 10-15 minutes to set up and take down but so worth it, unless of course just camping for a quick night. Recently experienced 7 inches of rain falling while in Catskills. We were out in Dome entire time and living room stayed dry. Awning people were holed up in their fiberglass box all day...wonderful.
Its so versatile. Can roll sides up completely for clear view. Roll screens down if buggy. Or completely seal in unsettled weather. I have even cooled and heated Dome by leaving Pod door open. THere has yet to be a storm that the Dome can't endure, however had to make a few modifications. 1. We crimped keder rail slightly with vice grips from one to other to make c channel tighter on Dome edge so now it can't fall out of keder. 2. Replaced stakes with real camping stakes and must hook all black loops into stakes firmly hammered into solid ground. 3. Replace stock suction cups with heavy duty ones. 4. Secure black flaps at bottom with weights if windy. We just use rocks from campground, but others use water jugs or other weights to secure it. We only do steps 2-4 if rain forecasted. Plus Dome becomes playpen for pets or kids and becomes a deterrent to any interest when away from Camp.
Stepladder kind of necessary to reach peaks and to elongate the 3 top poles, but we have ladder anyway for tip out cleanoff and to hang globe lights. You should be able to negotiate for Dome for free from dealer as we did. Best thing yet as it gets small inside pod.
------------- Outdoorsy Marc
2016 Rpod 179
2017 Kia Sorento SXL
Posted By: 4Papa
Date Posted: 04 Sep 2018 at 9:51pm
Four or so 6" bungie cords are also handy to help the suction cups reach awkward places or used instead of the cups entirely, like to hook the lower grommets to the stabilizers.
