Removal of outside microwave panel
URL: http://www.rpod-owners.com/forum_posts.asp?TID=12111
Printed Date: 26 Jun 2025 at 12:02pm
Topic: Removal of outside microwave panel
Posted By: Medicine Wolf
Subject: Removal of outside microwave panel
Date Posted: 24 Aug 2018 at 10:26pm
Okay I have a very simple question and after Googling I cannot find a simple answer. How do I remove the panel on my rpod 151 covering the back of the microwave. There are two rubber grommets at the bottom of the panel but I'm not sure what to do with them
Posted By: furpod
Date Posted: 25 Aug 2018 at 6:53am
There is no outside panel for the microwave. None. The panel you are describing sounds to be the access panel for the fridge. Rotate the center square of the "grommet" from horizontal to vertical, then jiggle it a bit, then pull the panel off.
Posted By: lostagain
Date Posted: 25 Aug 2018 at 7:04am
But, as with anything plastic on an RV, be gentile.  The plastic gets brittle with time and can easily break if forced.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Date Posted: 25 Aug 2018 at 7:49pm
Thanks.....my microwave fan stopped working forcing it to overheat and shut down.......then it started working again...have any of you had issues with exhaust fan on micro not work?
