KIB monitor panel schematic / wiring diagram
Forum Name: I need HELP!!!
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11997
Printed Date: 11 Jul 2025 at 7:38am
Topic: KIB monitor panel schematic / wiring diagram
Posted By: MadCity
Subject: KIB monitor panel schematic / wiring diagram
Date Posted: 04 Aug 2018 at 9:52am
Does anyone happen to have the schematic / wiring diagram for the KIB control panel? This is on a 2018 176T (not sure how standard they are across rpods) I'm switching over to a SeeLevel II and would like to use some of the existing wiring at the panel.
TIA!
2018 R-Pod 176T
2008 Honda Pilot AWD
Posted By: mcarter
Date Posted: 04 Aug 2018 at 3:38pm
I did a Google search on KIB wiring diagrams. GOOD LUCK. I have never seen a wiring diagram for anything in a Pod except for the 7 way and it was basic. I know I have built some wiring diagrams when working issues with my Pod.
Posted By: jimandclare
Date Posted: 04 Aug 2018 at 5:14pm
MadCity,
Was going to attempt the same mod a couple of years ago so I bookmarked these links but just never got around to it.  Below are the links that should answer your questions:
(How the system works ... or should work)  http://www.forestriverforums.com/forums/f113/troubleshooting-the-micromonitor-26746.html - Troubleshooting the KIB monitor
http://www.forestriverforums.com/forums/attachment.php?attachmentid=19893&d=1348605449 - KIB Monitor Wiring Diagram  (Download PDF File)
Hope this helps
Jim & Clare
2016 R-pod 178
2014 Ford Edge
Posted By: MadCity
Date Posted: 06 Aug 2018 at 9:38am
jimandclare,
That's exactly what I needed. I was able to successfully install the SeeLevel using the existing wires from each tank. Install took all of about 30 minutes. Thanks!
2018 R-Pod 176T
Date Posted: 06 Aug 2018 at 11:26am
Great! Glad to be of assistance.
Jim & Clare
2016 R-pod 178
2014 Ford Edge
