Door lock for 175
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11875
Printed Date: 27 Jun 2025 at 2:04pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Door lock for 175
Posted By: Murri
Subject: Door lock for 175
Date Posted: 10 Jul 2018 at 9:42am
i just purchased 2010 r175. Stupid door lock it very tricky. Any help?
------------- M
Posted By: furpod
Date Posted: 10 Jul 2018 at 9:46am
In what way is it.. "tricky"? Only 4 screws hold it in place. You should be able to remove it and see if it has gunk build up inside or something. Sometimes the strike plate needs adjustment if it isn't latching well, or if the deadbolt isn't going in and out easily.
Posted By: lostagain
Date Posted: 10 Jul 2018 at 10:01am
Congratulations on your purchase. On our 2009, which we purchased used, we found many items that were in need of a little lubricant, cleaning, and adjusting. As furpod says, the door lock is easy to remove and clean. I used a lithium spray lubricant that leaves a white residue (like you see when car dealers lubricate your car door hinges) on the moving parts with the exception of the key tumblers - where you put the key. It made a big difference the ease of closing and locking. Good luck with your new travel trailer. You'll find lotsa interesting stuff here to help you maintain it.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
