Power from TV to POD
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11493
Printed Date: 28 Jun 2025 at 12:28am
Topic: Power from TV to POD
Posted By: MDPaddlersPod
Subject: Power from TV to POD
Date Posted: 01 May 2018 at 8:17am
Can someone please tell me how I can check that I have power going from my truck to the POD. I am guessing that if I have power at my trucks 7 pin connector that power is going to the POD to charge the batteries when I am driving. Is this assumption correct? My other guess is that if there is power to the trailer lights there is also power to charge the trailer battery. Any help/advise would be greatly appreciated.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
Posted By: GlueGuy
Date Posted: 01 May 2018 at 8:25am
Not necessarily. There are separate wires for power, lights, brakes, and so on. The lights are easy to check.
For the brakes you should do a standard trailer brake check. What I do is just squeeze the trailer brake controller without touching the TV brakes, and barely moving. If you're on level ground the trailer brakes should be sufficient to stop both the TV and the TT.
For the power, it is probably easiest to use a DVM to check the voltage on the trailer battery/ies when you connect the 7-pin. With the TV running, you should see a step up in the battery voltage. Certainly over 13 volts; maybe a bit higher depending on the battery state of charge.
Posted By: StephenH
Date Posted: 01 May 2018 at 8:38am
On some tow vehicles, one needs to enable power to the connector. You could check by using a voltmeter on the TV's connector. The 1:00 terminal is the 12V power connector and the 7:00 terminal is the ground. If you have voltage there, it should charge.
See the http://www.etrailer.com/faq-wiring.aspx - Trailer Wiring Diagrams on etrailer.com for pictures.
Posted By: GlueGuy
Date Posted: 01 May 2018 at 8:45am
Our F-150 is tricky. It senses the presence of the trailer, and won't power the 12V connector unless/until the trailer is there and the truck is running. So I can't check the 12V with the trailer disconnected.
Posted By: Craneman
Date Posted: 01 May 2018 at 9:08am
You can check the voltage of the battery with the truck not connected should read around 12 volts ,then connect and start the truck your battery should read around 13-14 volts. My ford 2011 f150 had a relay in the glove compartment I had to install in the fuse box under the hood
   Moe
Jo and Gary
2010 174
2011 Ford 150
Date Posted: 01 May 2018 at 9:22am
GlueGuy, many thanks, I get it. Like checking the alternator output for a car at the battery. That makes sense to me, again thanks.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
Date Posted: 01 May 2018 at 9:23am
Thanks, guys, I get it now.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
Posted By: TheBum
Date Posted: 01 May 2018 at 11:10am
Some brake controllers have a continuity mode that sends a small current to the brakes continuously -- obviously not enough to engage them -- and an indicator light, so I use that to make sure the brakes (and the plug in general) are connected.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Date Posted: 01 May 2018 at 11:53am
Wow, thanks for all the responses guys, I really appreciate it.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
Posted By: Subzilla
Date Posted: 01 May 2018 at 1:07pm
To echo Stephen about enabling power, my '11 Silverado came from the factory without the brake controller and power wire connected.  The wires were installed but were tucked away under the fuse box under the hood.  There's even a lug on the fuse/relay box to connect them.  Easy to do, just had to buy the fuses, if I recall.
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Posted By: Olddawgsrule
Date Posted: 01 May 2018 at 3:48pm
Craneman did pretty much what I did to check. Hookup the Multi Meter and read 12+ volts and hook up to the truck (running) and check again. Jumped right up as I hoped and showed power to the batteries.
https://www.youtube.com/channel/UCJduGeZNFgtptH67leItRFQ - Byways no Highways
2017 Tacoma
http://tnttt.com/viewtopic.php?f=55&t=72408 - Truck Camper Build
2004 F150 My Overlander
