Trim separation
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11332
Printed Date: 28 Jun 2025 at 12:58pm
Topic: Trim separation
Posted By: lgblau
Subject: Trim separation
Date Posted: 31 Mar 2018 at 6:20pm
Hi. While doing wax on, wax off, I found that the trim on the right,rounded front edge,of my 2017 M179 has pulled away from the the side wall. I tried to push the trim back into position, but it would not close the gap. I can see the edge of the side wall. Any suggestions for a fix. This R-Pod is only a year old this month, and I am not the original owner. Thx.
Leonard🌵
2017/179
2017 Ram 1500
Posted By: furpod
Date Posted: 31 Mar 2018 at 7:03pm
Pull the plastic cover that is over the trim strip. Back the screws out in the area that is pulled away. Make sure they are not rusted or corroded. Get longer screws. Push the trim back in place, use the longer screws for a better, deeper "bite". Recaulk.. That last step is most important.
Posted By: lgblau
Date Posted: 31 Mar 2018 at 7:13pm
Sir, by plastic cover, do you mean the one at the very bottom right hand corner, with the two screws.
Leonard🌵
2017/179
2017 Ram 1500
Posted By: furpod
Date Posted: 31 Mar 2018 at 7:48pm
There is a plastic trim strip, about 3/4 in wide as it's inserted. That just pops out. It may have an anchor plate or tab at the very bottom/ends. It runs from the front all the way to the back.
Posted By: lgblau
Date Posted: 31 Mar 2018 at 10:33pm
furpod, I’m afraid it will make it worst if I start pulling the plastic trim off. I will send you a picture. Thx
Leonard🌵
2017/179
2017 Ram 1500
Posted By: furpod
Date Posted: 01 Apr 2018 at 7:20am
The plastic trim just pops in to the aluminum trim piece, all it does is protect the screws under it, and what they do is secure the trim and sidewall in place.
Posted By: lgblau
Date Posted: 01 Apr 2018 at 11:06am
Okay, furpod. I understand now. Thank you for your patience and knowledge. I think I will be able to fix this problem short of using duct tape. Have a great Easter day.
Leonard🌵
2017/179
2017 Ram 1500
