Pid floor
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11268
Printed Date: 28 Jun 2025 at 1:02pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Pid floor
Posted By: Keith-N-Dar
Subject: Pid floor
Date Posted: 19 Mar 2018 at 6:37pm
I need to make a small (1/2 inch) nole in the floor of our Pod. What is the floor made of, and what will I run into drilling this hole?
------------- Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: furpod
Date Posted: 19 Mar 2018 at 6:48pm
Linoleum, luan, foam, luan, vapor barrier.
Unless you hit one of the aluminum framing members, that is all there is between you and the ground.. Don't forget the chassis/frame itself is inside the wall width.
also, if you drill from below.. it will be vapor barrier, luan, foam, luan, linoleum.
Posted By: mcarter
Date Posted: 19 Mar 2018 at 6:49pm
I have drilled thru the floor of my pod. There is no wiring or plumbing. Once I determined the place away from braces and other bottom hardware and internal mounted things, I drilled thru, not an issue. I sealed hole on bottom and silicone inside where hole was.
------------- Mike Carter
Posted By: lostagain
Date Posted: 19 Mar 2018 at 8:37pm
Personally, if I penetrated the vapor barrier on the underside of our Pod, I'd use a marine through hull fitting to seal it off. Here's an example. https://www.go2marine.com/product/387052F/attwood-straight-thru-hull-connections.html?WT.srch=1&WT.mc_id=gb1&utm_source=googlebase&utm_medium=productfeed&utm_campaign=googleshopping&gclid=EAIaIQobChMIjNzq8d_52QIVio9-Ch3MaQ0lEAQYAyABEgKyEPD_BwE
They are available in a variety of diameters. Then, what ever you plan to put though the hole, not counting your finger, can be well sealed up so water and crud doesn't get in. It's probably overkill, but many foams don't like to be contaminated with the crud found on the road. It slowly deteriorates and you end up with a squishy floor like the ones found around leaks in the head. For example, if you wanted to run a wire or a piece of copper tubing through the hole, you could fill the excess space with a good bedding caulk, like 3M 5200, and it would probably last longer than the trailer.
Just a thought, though.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Posted By: furpod
Date Posted: 19 Mar 2018 at 9:16pm
Just a thought, though. |
I made my own bulkhead from some PVC fittings.. but you are dead on about sealing and protecting..
Date Posted: 20 Mar 2018 at 7:45am
Thanks. now I can drill with confidence.
2011 R-Pod 177
2010 Ford F-150
Posted By: mcarter
Date Posted: 21 Mar 2018 at 5:26pm
Interestingly, while working on my Pod I have found many attachments to the bottom with 1"X14 self tapping screws that had absolutely no sealant associated. That was from factory. I have since sealed them, I used Flex Seal available from Lowe's in both brush on and spray.
