Water pressure controller
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11239
Printed Date: 28 Jun 2025 at 6:23pm
Topic: Water pressure controller
Posted By: henryv
Subject: Water pressure controller
Date Posted: 12 Mar 2018 at 7:14pm
Which water pressure controller is best?
Posted By: CharlieM
Date Posted: 12 Mar 2018 at 8:01pm
IMO the Fairview WR-RV55 available from  https://www.rvwaterfilterstore.com/Fixed.htm - https://www.rvwaterfilterstore.com/Fixed.htm . It supports a much higher flow rate than cheaper versions from Camping World, Camco or Valterra.
Posted By: Larry-D
Date Posted: 12 Mar 2018 at 8:15pm
This is the one I'm using.  I had one of the more inexpensive ones go bad and let too much pressure into the pod on our first outing.  Sitting at the picnic table watching water run out the bottom of the pod...bad.  The ones like the one I'm using adjust with a plain screwdriver so that if you run into a high pressure space, easily dialed down and the reverse is true.
https://www.amazon.com/gp/product/B01MR6WNB1/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
