Electrical backup lights
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11089
Printed Date: 28 Jun 2025 at 7:55pm
Topic: Electrical backup lights
Posted By: rawest50
Subject: Electrical backup lights
Date Posted: 24 Jan 2018 at 8:44pm
I have a light bar I want to put on the rear of the Pod. I have plenty of wiring to run the length from the TV to the rear of the Pod. I need the reverse lighting on the TV. Wiring diagram shows the center pin of the 7 pin as the reverse wiring. Can I splice into it and make it work? The light works off a 4 pin but my past experience is that does not handle the reverse lighting. My Jeep I wired into the taillight.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Posted By: marwayne
Date Posted: 24 Jan 2018 at 9:12pm
If you look under the pod on drivers side, where all the wiring is located there is a yellow wire that is blanked off that is for the backup light.
https://postimg.org/image/5gpenblp1/">
Posted By: rawest50
Date Posted: 24 Jan 2018 at 9:48pm
Thanks. I will check it out. May be back because my Electrical skills are plugging prongs in a socket.
2017.5 RPod 179
2 Weiner dogs
Posted By: rawest50
Date Posted: 05 Mar 2018 at 4:57pm
I am back. I used my iPhone to check for a yellow wire. I cannot get under the Pod because driveway slopes & front of Pod very low to make it level. I have a bunch of white wired and a couple not connected to anything. No yellow. I will try to post a picture.
2017.5 RPod 179
2 Weiner dogs
Posted By: DenisP
Date Posted: 07 Mar 2018 at 3:06pm
I just completed wiring backup lights on my 2010 171.  I found the yellow wire under the left front corner and made the connection.  Works great.  Thank you Marwayne.
T@b 400 with solar
Formerly 2010 171
2013 Tundra TRD
Posted By: rawest50
Date Posted: 07 Mar 2018 at 4:01pm
Drivers side at the front corner? That is where all my wires go from the frame to the trailer underside.
2017.5 RPod 179
2 Weiner dogs
Posted By: marwayne
Date Posted: 07 Mar 2018 at 6:18pm
rawest, you are right the wiring comes in on the drivers side.
Now since I'm such a nice guy I crawled under the pod in the snow to take a pic just for you.
https://postimages.org/">
Posted By: rawest50
Date Posted: 08 Mar 2018 at 9:19am
Thanks. I take our Pod in for service tomorrow so when I have it high enough I will crawl under and get a better look. I used a selfie stick and took pictures but could not separate any of the wires. It is problay there covered by all the other wires.
2017.5 RPod 179
2 Weiner dogs
