Please help, EU2000i connection question
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11072
Printed Date: 28 Jun 2025 at 11:53pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Please help, EU2000i connection question
Posted By: Susie Q
Subject: Please help, EU2000i connection question
Date Posted: 17 Jan 2018 at 1:21am
Hi, wondering if someone can recommend the manufacturer of a pigtail that will connect the Honda EU2000i 30 amp female outlet to the rpod's 30 amp male twist lock plug. I think this Honda generator has a twist lock female 30 amp plug.
Posted By: furpod
Date Posted: 17 Jan 2018 at 7:23am
You don't connect to the connection on the side of the pod. You use an adapter on the plug in end of the pods power cord.
https://smile.amazon.com/Conntek-Generator-Adapter-Straight-Connector/dp/B003I2RZRS/ref=sr_1_3?s=sporting-goods&ie=UTF8&qid=1516195333&sr=1-3&keywords=RV+20amp+adapter - Adapter
You asked about a 2000i. Are you using a 2000i Companion? If so, that adapter above will work fine, but there is this option..
http://www.amazon.com/Atima-3-Prong-Generator-Adapter-Connector/dp/B06WGP1JMR/ref=pd_sbs_86_3?_encoding=UTF8&pd_rd_i=B06WGP1JMR&pd_rd_r=9YMZZH9V2T8C4VJ3TQTP&pd_rd_w=csx70&pd_rd_wg=Lr3xy&psc=1&refRID=9YMZZH9V2T8C4VJ3TQTP - Optional Companion Adapter
Or 2 2000i's, a standard and a companion, tethered? If that is the situation, you need the companion adapter kit that includes the crossover cables and plug.
http://www.amazon.com/Honda-08E92-HPK2031-Companion-Cable-Adapter/dp/B004DQWJ3S/ref=sr_1_20?s=lawn-garden&ie=UTF8&qid=1516199798&sr=1-20&keywords=honda+generator+eu2000i+accessories - RV adapter and cables
Posted By: Tars Tarkas
Date Posted: 17 Jan 2018 at 8:10am
It seems unlikely that a 2000w generator would have a 30A outlet, but regardless, you should be able to find what you need on Amazon or at Walmart or Camping World, etc. Like Furpod said, the adapter should plug into the generator and the pod power cord should plug into the adapter. The one he linked to should be exactly what you need.
TT
------------- 2010 176
FJ Cruiser
Posted By: TheBum
Date Posted: 17 Jan 2018 at 9:58am
The EU2000i Companion has a marine 30A socket. Of course, the only way you'll actually get 30A out of it is if you're running a second generator in parallel, which can be a regular EU2000i. This is the adapter we use:
https://www.amazon.com/exec/obidos/ASIN/B0011FJXOM - https://www.amazon.com/exec/obidos/ASIN/B0011FJXOM
------------- Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Posted By: Susie Q
Date Posted: 17 Jan 2018 at 12:46pm
