mod 178 bath wall
URL: http://www.rpod-owners.com/forum_posts.asp?TID=11006
Printed Date: 29 Jun 2025 at 5:17am
Topic: mod 178 bath wall
Posted By: TEDDY
Subject: mod 178 bath wall
Date Posted: 15 Dec 2017 at 1:42pm
My 178 (2017) has a plastic-lined wet bath - great.  However, my wife needs a handle to help her get up off the commode.  The wall between the rear queen bed and bath is about 4-1/2" thick, and it's just two layers of luan - no support for a handle.  The framing at the inner corner is not accessible to drill into for the handle.
Has anyone figured out how to affix a handle (or anything else) to that wall that might work for me?
Teddy
Posted By: TEDDY
Date Posted: 10 Jan 2018 at 6:01pm
What I finally did was purchase as set of potty rails (fold-up) from Amazon.  It's actually about 1/2" too wide, but it does "fit."  I wound up cutting off about 1 inch from the bottom of the extendable legs to make it more comfortable to use.
Teddy
Posted By: geewizard
Date Posted: 11 Jan 2018 at 9:27am
When I took my sink out, I saw wood "studs" in the wall between the bath and the bed area so it's not just two layers of luan.  A studfinder found the studs in my Pod.
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Posted By: TEDDY
Date Posted: 11 Jan 2018 at 9:59am
Thanks .. I'll use my stud finder to look for them.
Teddy
Posted By: mcarter
Date Posted: 11 Jan 2018 at 10:06am
Teddy,
You should have an access panel on bed side of wall, if you remove, I think you can see those vertical studs.
