Smoking battery
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10737
Printed Date: 01 Jun 2025 at 8:41pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Smoking battery
Posted By: NW explorer
Subject: Smoking battery
Date Posted: 30 Sep 2017 at 2:49pm
Hello all, I'm the proud owner of a 2014 177 that my wife and I use for exploring the great pacific NW. Recently we were camping at Cape Disappointment in Washington when the R Pod battery started smoking and smoldering. Actually, we had unhooked the trailer from my truck in order to go fishing for a few hours. When we returned a neighbor camper notified us that while we were gone the campground started to have a strong sulfer odor so he looked around and found the battery smoking. He turned off the campsite electric panel and the battery eventually stopped smoking. Does anyone have an idea what could have caused this to happen?
Posted By: mcarter
Date Posted: 30 Sep 2017 at 5:04pm
Normally this would be indicative of a shorted battery, somehow a negative plate has made contact with a positive plate. There could be other causes but, start with removing the old battery, have it tested, it will be bad. Get another battery and run a controlled experiment, that will give you chance to monitor charging system and loads. You need a meter and some basic knowledge. The charging system when working right is controlled, so I think that will not be the issue, but without testing, who knows. There are many engineers in the world who can tell you how things works, but when they don't - clueless.
------------- Mike Carter
Date Posted: 30 Sep 2017 at 5:35pm
Thank you Mike, sounds like a good start to figuring this out.
