Leaking at the front cornersRp177
Category: Non-pod Discussion Forums
Forum Name: Mods, Maintenance, Tips and Tricks
Forum Discription: Same as podmods, just... not for pods
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10726
Printed Date: 13 Jul 2025 at 2:19pm
Topic: Leaking at the front cornersRp177
Posted By: Jimmer
Subject: Leaking at the front cornersRp177
Date Posted: 28 Sep 2017 at 9:16pm
I noticed a softening on the front corners at the side, of the bottom. Upon investigation I found water had gotten into the entire front at the bottom leading edge. Opened it up all across the front , found the wooden liner of the fiberglass skin had rotted, about a foot up all along the front, the insulation was wet in this area too. The front bottom corners were rotted too.
Looking for solutions to repair this.
Thanks
Jim Hogan
Posted By: RobnCari
Date Posted: 26 Nov 2017 at 10:38pm
Tough one. Warranty? Otherwise a front end rebuild would be in order.
2006 Toyota Tacoma 4WD AC
2018 RP 179
Posted By: mcarter
Date Posted: 27 Nov 2017 at 8:39am
I think repairing it should be second to finding source, if water is getting in where water shouldn't be it will rot again. May be simple find, may not. From your description it is in the area at bottom of gravel guard? If TT is under warranty, use it. If not could be an good project to fix.
