Check your factory installed gas lines
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10243
Printed Date: 30 Jun 2025 at 5:39am
Topic: Check your factory installed gas lines
Posted By: Subzilla
Subject: Check your factory installed gas lines
Date Posted: 27 Jun 2017 at 7:50am
While installing my WDH brackets on the trailer last night, I had to loosen the gas and electrical lines.  Started really looking at the gas lines under the trailer and found a major kink...like when you over bend a garden hose and it kinks flat.  This was the major supply line at the aluminum manifold where the other lines split out.  FR had turned this line 180 degrees back toward the front of the trailer and not allowed enough length of the line for the bend.  The hose was flat at the bend!  When using the stove, I had noticed a very long delay for the gas to get to the burners and we were having fridge starting issues on our trips using gas.....makes wonder if this was the problem.   I re-positioned the manifold and lines as best I could to reduce the kink considerably.  It really needs a longer hose to make it right.  Eager to try to the gas appliances now.
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Posted By: Live2Camp
Date Posted: 27 Jun 2017 at 11:56am
So noted and thanks for the heads up on this critical piece of equipment!
2017 R-Pod 179 HRE (the green one)
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
Posted By: voisj
Date Posted: 27 Jun 2017 at 7:28pm
That's a "will check soon" thanks!
http://www.rpod-owners.com/forum_posts.asp?TID=9426&title=slopod-180-mods-johnsue - SLOPODMODS
John&Sue,SLO,CA
