Jeep Unlimited Sahara towing a 181G
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10206
Printed Date: 30 May 2025 at 2:14am
Topic: Jeep Unlimited Sahara towing a 181G
Posted By: juzdon
Subject: Jeep Unlimited Sahara towing a 181G
Date Posted: 20 Jun 2017 at 1:49pm
I have a 2011 181G that I pulled with my Sport Trac.  I recently purchased a 2011 Jeep Wrangler Unlimited Sahara.  I'm nervous about towing my rPod and was wondering if anyone has any experience or thoughts.  The 181G has a GVWR of 3787 and from what I've found the max towing on the Jeep is 3500.  I will only be taking it short distance (travel time 30 minutes) and will have an electronic brake.  Thoughts? Thanks in advance.
Posted By: Tars Tarkas
Date Posted: 20 Jun 2017 at 8:21pm
Well, the GVWR is supposed to be as heavy as the pod can get, so it probably won't usually be that heavy, but perhaps most important, you'll have serious liability issues if your in an accident, your fault or not, pulling a trailer to heavy for your vehicle.
I like to stay around under about 80% of the vehicle rating in terms of comfort and safety.
All that said, if it were me, I might do it if it's really only 30 minutes on the road.  I'd plan on being extra vigilant.  I'm not always too smart.
TT
FJ Cruiser
Posted By: Jpntime
Date Posted: 20 Jun 2017 at 10:22pm
 I would load the trailer with all your stuff and have it weighed unhook from the jeep and then you could decide how much water or supplies you need to take to make it legal under the 3500 pounds  we pull our rpod with the 2013 JK I had it weighed with everything in it and it weighed about3100 pounds and it's a 171
Love to camp
2014 171
Posted By: ToolmanJohn
Date Posted: 21 Jun 2017 at 5:25am
 It would be interesting to see if you could load up to the full gross weight capacity.
That being said. If you know the unloaded delivered weight of the unloaded pod (sticker weight) you could weigh you camping cargo on a bathroom scale and write down each items weight as you load. Take fresh water into account too (8.34 pounds per gallon).
Be aware that the battery and propane might not have been included on the delivered weight sticker. You might have to add those to the total as well.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Posted By: juzdon
Date Posted: 21 Jun 2017 at 1:18pm
thanks for the replies!
i normally have the pod parked on vacant land i have near a small lake but reserved a spot at a campground about 30 minutes away before i purchased the Jeep.
being the campground is fairly close, i may just try and take it on the back roads, stripped of supplies, and see how she handles.
Posted By: kent l
Date Posted: 29 Jun 2017 at 9:55pm
Hi,
I tow my r-pod 178 with a 2012 jeep Rubicon unlimited. The jeep is lifted with a 2.5 inch AEV lift, it has 35 in tires and 4:10 gears. I have a Anderson WDH with anti sway built in it. I live in a Mountain Valley in Utah. I have pulled it to Wyoming over many mountain passes. I have pulled it in the winds of Wyoming and Idaho with out any problems I don't go over 70. It seems to pull best at 65 some times over steep mountain passes I have to go to the lowest gears but that is pulling with a gas rig. Have pulled it over 2,500 miles with no problems
http://www.rpod-owners.com/forum_posts.asp?TID=3539&PN=60&title=pictures-of-tow-vehicles-and-trailers - http://www.rpod-owners.com/forum_posts.asp?TID=3539&PN=60&title=pictures-of-tow-vehicles-and-trailers
Posted By: computerfixitguy
Date Posted: 04 Jul 2017 at 12:21pm
Same here, I have a Rubicon, although, like the 2012 with the bigger motor.  Outside of hills, the weight isn't a problem.  I have the Equalizer hitch as well.  Trailer gets squirrely without it.  Mine starts at 2700 and I am sure gets over 3500 when water is in it, but we get water close to destination.  RV Parks will let me fill up for 5 bucks.
Kim & Derek
2016.5 176t
2015 Jeep Rubicon JKU (trips west)
2008 Town and Country (trips east)
2 kids, 2 dogs
Posted By: tabrods
Date Posted: 04 Jul 2017 at 7:55pm
The most important thing with a Wrangler is the gearing and auxilary cooling if you have an auto tranny. If you have a standard tranny you won't need it. If you're gearing is 3.73 or 4.10 or higher you should be fine. There is a way to see your build sheet for the Wrangler but I don't remember how. Someone on the Forum knows how to look it up.
Tom
