Battery wing nuts coming loose
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10202
Printed Date: 30 Jun 2025 at 3:32am
Topic: Battery wing nuts coming loose
Posted By: GLBCamper
Subject: Battery wing nuts coming loose
Date Posted: 20 Jun 2017 at 10:12am
the wing nut on my negative battery terminal keeps loosening to the point of causing a short, even on fairly short trips. I doubt I can use something like locktite because it's not conductive. Anyone have this problem? Solutions?
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Posted By: StephenH
Date Posted: 20 Jun 2017 at 10:15am
Switch to regular nuts and use a second one on top to act as a lock-nut. I only use one regular nut on each of the terminals, and have not had a problem with them coming loose. I do tighten them down with a wrench. That might be what is making the difference.
Posted By: TheBum
Date Posted: 20 Jun 2017 at 10:51am
Maybe get some split lock washers. I wouldn't advise using star washers because of the limited electrical contact.
Posted By: mcarter
Date Posted: 20 Jun 2017 at 4:55pm
+1 - no wing nuts.
