Generators
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10154
Printed Date: 29 Jun 2025 at 10:34pm
Topic: Generators
Posted By: DawgLady
Subject: Generators
Date Posted: 13 Jun 2017 at 10:36am
I have 2 Honda EU2000 generators. If I hook them in parallel with the 2 wires from Honda, do I have
To have a 30 amp rec or can I use the 110 rec on the generators to run my air conditioner?
Thanks for your help.
Sara
Dawg Lady
2016 R-180 "Lizzy"
Georgia
Posted By: TheBum
Date Posted: 13 Jun 2017 at 12:59pm
If one of the generators is not a Companion model with a built-in 30A receptacle, then you'll need a special parallel cable with a 30A receptacle. Here are a couple of aftermarket options:
This one would work as-is with the R-Pod power cable:
https://smile.amazon.com/Yamaha-RV-Parallel-Power-Cables/dp/B00V8SKDGO/ - https://smile.amazon.com/Yamaha-RV-Parallel-Power-Cables/dp/B00V8SKDGO/
This one either needs an adapter to plug the R-Pod power cable into, or will plug directly into the socket on the R-Pod where the power cord normally goes:
https://smile.amazon.com/Smarter-Tools-ST-PKIT2000-Inverter-Generator/dp/B00K2YDNWG/ - https://smile.amazon.com/Smarter-Tools-ST-PKIT2000-Inverter-Generator/dp/B00K2YDNWG/
