Propane Gas connection
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10142
Printed Date: 29 Jun 2025 at 8:57pm
Topic: Propane Gas connection
Posted By: rawest50
Subject: Propane Gas connection
Date Posted: 10 Jun 2017 at 7:51pm
Learned tonight the RPod has a regulator. Never noticed it before. Hook up my grill with a regulator and I have low flame. Just passing the info along.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Posted By: shroomer
Date Posted: 11 Jun 2017 at 2:40pm
I have been following similar discussions on another forum. This seems to be the issue:
All your appliances run off a lower pressure than what comes out of your tank so there must be a regulator to drop the pressure. Your grille normally hooks directly to the propane tank and the gas pressure is regulated by a device on the grille itself that reduces it. If you're getting gas downstream of the  pod's regulator and your grille is reducing it further, you would get an insufficient flow of gas. Campers who use grilles downstream of the trailer's regulator need to remove the regulator from their grille.
Search around - there are a lot of discussions about this since many other trailers come with low pressure lines available for grilles.
Posted By: furpod
Date Posted: 11 Jun 2017 at 2:44pm
Yes, you have 2 options, get a T that allows you to pull from the tank BEFORE the regulator, and use you grill as is, or convert your grill to low pressure and use it from the pod lines.
Youtube has several videos that explain the method and give parts lists.
Posted By: rawest50
Date Posted: 11 Jun 2017 at 7:10pm
Thanks folks. I can handle that.
2017.5 RPod 179
2 Weiner dogs
