Ccan I use an extension cord?
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10011
Printed Date: 29 Jun 2025 at 10:28am
Topic: Ccan I use an extension cord?
Posted By: Robwid
Subject: Ccan I use an extension cord?
Date Posted: 22 May 2017 at 11:58am
The power cord on my Pod is about 10 feet short of an electrical outlet.  Can I add an extension cord?  I'd like to make sure my batteries are fully charged for the coming holiday weekend.  I have a 10 foot 16 guage cord or a 50 foot 14 guage cord.  Would either of these work?  Could I also turn the frig on propane or would this be too much electrical draw?
As always, thanks for your advice!
Rob
2012 HRE 177
2010 Toyota Tacoma
Posted By: john in idaho
Date Posted: 22 May 2017 at 12:23pm
I think you will be fine.  A turn of duck tape around the joint would be a good temporary moisture seal.  It should even run the fridge.
Posted By: mcarter
Date Posted: 22 May 2017 at 5:30pm
Robwid,
I take you are talking about running on a 110 VAC outlet to your Pod. Yes with proper adapter you can attach the extension to your POD power outlet, I used to do this to charge battery before I added a 30 amp service to my building. You can't run AC or microwave. I would use the 14 gauge cord, or buy a good outdoor heavy duty extension. From 110 you're limited to amps on line. If you get wet weather, I suggest you disconnect and wait. Happy Trails.
Posted By: voisj
Date Posted: 22 May 2017 at 7:24pm
I have my pod plugged in on a 110v 20 amp circuit​ with a 100 foot 12 gauge extension cord. ( On a farms back 40). The 110 is only used to keep the batteries charged,and I've had no issues with it. I have pre cooled the refer with it,but it's just as easy to use propane for the night.I put the electrical cord connection​ under the pod to keep it out of the weather.
http://www.rpod-owners.com/forum_posts.asp?TID=9426&title=slopod-180-mods-johnsue - SLOPODMODS
John&Sue,SLO,CA
