Something not to do getting ready for summer
URL: http://www.rpod-owners.com/forum_posts.asp?TID=10002
Printed Date: 29 Jun 2025 at 10:44am
Topic: Something not to do getting ready for summer
Posted By: john in idaho
Subject: Something not to do getting ready for summer
Date Posted: 21 May 2017 at 2:39pm
Time to take the 179 pod out of the barn.  I took the spare and mount out and slid them  under the rear of the trailer in the fall for more walking room behind.  Moving stuff out of the way, I look at the spare, and think - I will just move ahead about 6 feet and then put the stinger on the tire mount into the socket and drive out the door.   Then I won't have to carry the spare and mount outside.  Good plan.  Except I had to raise the front of the trailer quite a bit to slide over the ball on the truck because of the incline in front of the barn door.  Which resulted in the stinger poking a 1 1/2" hole in the floor. of the pod.  Looking behind the bottom drawer, the inner surface of the floor was just dimpled slightly.  Nothing that a can of foam filler won't fix.  If I didn't keep getting in my own way, I would never get anything accomplished.
Posted By: Leo B
Date Posted: 21 May 2017 at 2:43pm
Ouch!
Posted By: yakinator
Date Posted: 21 May 2017 at 2:57pm
Murphy's law takes the lead in the winner take all contest of world domination.
2017 RPOD 180 named VentuRpod
Posted By: StephenH
Date Posted: 21 May 2017 at 8:00pm
I lost the sewer hose carier when I wanted to take the R-Pod out of the driveway without the Equal-i-zer bars hooked up to test the Hayes No-Sway I had purchased. Between the driveway's slope and the curb gutter, it bottomed out just enough to break the mounting brackets. I now know that I need to put something down to eliminate that dip at the end of th edriveway before I try something like that again. The fix for mine was not too bad. I just had to order new doors and brackets, and do a little cementing of them on the tube which I had to repair since it got cracked also, but only at one end and not bad enough to buy a whole new tube.
Your puncture is worse. I hope you can patch it up sufficiently so there wll be no additional damage.
