  New Posts New Posts RSS Feed: Hot water heater rod
Topic ClosedHot water heater rod
henryv View Drop Down
Direct Link To This Post Topic: Hot water heater rod
    Posted: 05 May 2017 at 5:38pm
At the bottom center of the hot water heater is a rod that screws in. What is that and does it stay in? Mine is rusty.
mcarter View Drop Down
Direct Link To This Post Posted: 05 May 2017 at 5:57pm
It's your anode rod. You should pull an inspect with each winterization. Clean the threads, flush your hot water tank and reinsert if it's OK.
Direct Link To This Post Posted: 05 May 2017 at 6:00pm
Don't get worried if it starts deteriorating, that is normal. I will usually change it out after 2-4 years
Direct Link To This Post Posted: 05 May 2017 at 7:15pm
Probably lasts different lengths of time depending on your water source.  Ours has never seen or tasted municipal/city water.  Only well water, 99% of the time ours.  Still on our original anode rod, on our 2011 r-pod.
GLBCamper View Drop Down
Direct Link To This Post Posted: 05 May 2017 at 8:33pm
I had a hard time getting a good seal this year because the female threads in the heater were quite rusted. I buffed it and the threads on the anode with a mild brush on my dremmel but it still took quite a bit of pipe dope to get a good seal. I left it stored for the winter with the anode out. Is there something I should be doing to prevent the connection on the WH side from rusting? Can that be replaced without replacing the entire heater? DIY?
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 06 May 2017 at 6:39am
Nope, it's permanent. While anything can be done with enough $$$.. it wouldn't be worth it to try to repair. That said, I have never heard of one needing it. Yes the threads rust a bit. I just hit them with a toothbrush, fresh two layer wrap of teflon tape, insert, tighten until firmly snug. Our Airstream's WH is 35 years old.. works the same way..
I always stored with the anode in, one less thing to do in the spring, and keeps the threads protected. New TT doesn't have an anode.. so.. Thumbs Up
Direct Link To This Post Posted: 06 May 2017 at 7:04am
Ditto!
Q7-retired View Drop Down
Direct Link To This Post Posted: 06 May 2017 at 8:21am
Just in case readers don't know what is an anode rod, please know is is a sacrificial piece of metal that is intended to rust and corrode away instead of the metal of your hot water heater.  In combination, certain metals form a galvanic cell, like a battery.  The less "noble" metal corrodes away (see https://en.wikipedia.org/wiki/Noble_metal).
There are many uses for sacrificial anodes, and you may have seen them with your homes electric water heater (the heating element is less noble), underground tanks, water intakes on ships and generally anywhere the presence of moisture allows the creation of a galvanic cell.  Bottom line for podders is that the rod in your water heater is meant to corrode and be replaced.  One normally removes the rod during winter storage to ensure the heater is empty of water.
Best regards, Jim
2015-RP178
TV 2015 Audi Q7 TDI and 2017 Ford F150
At home in "Our Pod"
