  New Posts New Posts RSS Feed: sway bar
Topic Closedsway bar
Gregm View Drop Down
Direct Link To This Post Topic: sway bar
    Posted: 06 May 2016 at 6:44pm
I am fairly new to the Rpod forum and we have owned our 2014 171 since 10/15 and have 2 previous trips with no issues
I am towing with a Toyota Tacoma Prerunner V6 and it pulls very well. We did have quite a bit of sway last weekend coming back from St Augustine Fl to Orlando though it was windy. I am considering installing a sway bar and would like to get input from the other forum members.
Thanks!
Mountainrev View Drop Down
Direct Link To This Post Posted: 06 May 2016 at 6:46pm
I have one.  For the small cost (<$100) and easy installation, I think it's worth it.  Lots of Podders have weight-distributing hitches that include anti-sway, and swear by them.  I may end up going that route some day.
2014 177
Direct Link To This Post Posted: 06 May 2016 at 6:52pm
Thanks for the info. Is there a particular brand and how difficult was the installation? I am somewhat handy and would prefer to install myself
Direct Link To This Post Posted: 06 May 2016 at 7:44pm
I installed the Pro Series friction sway control from E-trailer ($38).  You also need to purchase a bracket which mounts under your existing ball, to which you will mount the little ball that the sway control arm rides on.  They run about $30.
Installation was simple.  Drill a few holes in the tongue of the trailer to mount a bracket with a ball on it, and then remove the ball from your ball mount, place the other bracket under it, and reinstall the ball.  Less than an hour of work.
2014 177
Direct Link To This Post Posted: 06 May 2016 at 7:50pm
Sounds doable. I appreciate your help.
sailor323 View Drop Down
Direct Link To This Post Posted: 08 May 2016 at 3:31pm
The Pro Series friction sway bar that I ordered from Amazon cam with all the necessary parts, $38 http://www.amazon.com/Pro-83660-Value-Friction-Control/dp/B0016KJ5MC?ie=UTF8&keywords=proseries%20sway%20bar&qid=1462735808&ref_=sr_1_sc_1&sr=8-1-spell
Direct Link To This Post Posted: 08 May 2016 at 5:40pm
We have the same Pro Series set up on our Explorer.  Have used this since spring 2011 and wouldn't go anywhere towing the pod w/o it.  Works great even when encountering strong cross-winds in excess of 20 mph.
