Originally posted by RoadToad
thanx for all the info. I have one more ? Goes like this: I have my pump on and I'm hooked up to city water. Whenever I turn on water at sink pump comes on until I shut faucet off. Then it occures to me: Do I really need pump on if my water system is hooked up to city water pressure?? Can't I just turn pump off and run on city water pressure?? And another ?: If I turn on my electric water heater will the propane heater shut off? Or is the switch inside ONLY for the propane water heater?? And I should shut the switch off inside to shut the propane water heater off. |
No need to run the pump when on city water.
I have read on here somewhere that the electric side of the water heater is set to come on a little lower than the gas side so when you are on someone else s electric the water will heat off of that first and conserve your LP.
The switch inside the Pod is only for the gas side.
(We bought our Pod used, took us almost a year to find out it worked on electric too....................)
You can leave the gas heater on if you are in a big hurry to heat hot water, other wise if you are patient you can burn someone elses power.
Life would be a lot tougher with out this Pod Forum.
I should read more carefully to see if there is a second page. Would have saved some typing
