Topic: 2011 Rpod 172 Flush slow Posted: 18 Aug 2015 at 12:45pm |
Originally posted by rudyunknown
And fixed...i removed the water line from the back of the potty...the pressure there was good, so i put my finger in the inlet to the potty and found a lot of debris....poked arnd a bit with a small stick removed all the gunk...and the fulsh is good as new :) |
Excellent.
rudyunknown
Posted: 18 Aug 2015 at 11:20am |
2011 Rpod 171
Tundra
Rudy Reshmi n big Omkar n lil Arjun
rudyunknown
Posted: 18 Aug 2015 at 11:01am |
Nope not the blackwater flush. I am talking about the flush in the potty, the pressure in there is low. I will take the hose of the back of the potty and check and report back.
2011 Rpod 171
Tundra
Keith-N-Dar
Posted: 18 Aug 2015 at 9:24am |
He may also be talking about the blackwater tank flush. More information needed.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted: 18 Aug 2015 at 8:24am |
It sounds as if you know the problem, debris in line or valve.. Turn off the water, reach behind the toilet, pull the line from the toilet valve, (it unscrews) see how much pressure you have. If you have good pressure there, it's the valve on the toilet itself.. pull it and check it.
Tars Tarkas
Posted: 18 Aug 2015 at 8:20am |
If you're talking about the fresh water line, I think about the only thing to do is remove screens an filters and flush it out.
TT
FJ Cruiser
rudyunknown
Posted: 18 Aug 2015 at 8:12am |
Nothing on this??
2011 Rpod 171
Tundra
rudyunknown
Posted: 14 Aug 2015 at 3:06pm |
Hi All Our potty flush was working fine when we hooked up last time. I think there was way too much debri in the water tap and i didnt flush it in time, so for now the water pressure everywhere in the rpod the sink and the bathroom taps are fine. But the potty flush has slowed down. Is there a way to flush out the debries any chemicals that people might have used to soften the debris, or do i have to wait for it to come out whenever it works its way out. Any thoughts? Thanks Rudy
2011 Rpod 171
Tundra
