hogone
Calendar Event: erratic brake light connection Posted: 18 Nov 2014 at 6:19am |
outbound; agree, good point. so what your saying is that if i notice my brake controller light go out, i have likely lost all lights/connections to the pod.....correct? hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
kymooses
Posted: 18 Nov 2014 at 9:50am |
Originally posted by hogone
outbound; agree, good point. so what your saying is that if i notice my brake controller light go out, i have likely lost all lights/connections to the pod.....correct? hogone |
Mine has done that in the past, pulled out even in the slightest and I would lose turn signals on one side etc. Give it a good push back in at the next gas/rest stop and good to go.
Goose
Posted: 18 Nov 2014 at 11:51am |
When we moved to AZ. I borrowed my neighbors car hauler for a couple of trips, the 7-way on the trailer was cheaper than the plug on the POD and would not make a constant connection. I had to use the needle nose pliers to bend the brass tabs on the trailer end just a hair at the corners so they bowed to the inside and would make a positive connection to the Jeep. With any of our other trailers I have never had a connection issue. Goose
Seanl
Posted: 18 Nov 2014 at 1:19pm |
On a 4 pin I have had situations where some lights worked and others did not even though they were all fed by the same wires. Turned out to be a ground problem. some lights found an alternative ground like the trailer hitch and you would get a week light but others did not. No lights.
headcold
Posted: 18 Nov 2014 at 5:40pm |
I had the same problem as described above. The tail lights and brake lights would flicker as I went down the road. It turned out that my ground was compromised each time I went over even the smallest bumps in the road because the hitch ball mount was rusted and rode loosely (rattled) in the receiver tube. I sanded down the shaft of the hitch ball mount and shimmed a piece of aluminum sheeting to keep the hitch ball mount tight in the receiver and never had that problem again.
Seanl
Posted: 18 Nov 2014 at 5:56pm |
Originally posted by headcold
I had the same problem as described above. The tail lights and brake lights would flicker as I went down the road. It turned out that my ground was compromised each time I went over even the smallest bumps in the road because the hitch ball mount was rusted and rode loosely (rattled) in the receiver tube. I sanded down the shaft of the hitch ball mount and shimmed a piece of aluminum sheeting to keep the hitch ball mount tight in the receiver and never had that problem again. |
You shouldn't have to do this if you have a good ground wire in your trailer hitch wireing. You should not depend on the ball on your hitch for electrical ground
Happy Tripping
Posted: 25 Nov 2014 at 2:54pm |
Thanks, Outbound, and the others too.
As follow up, part of the confusion is that i misunderstood my wife, ALL the lights were out and then working after wiggling so the trailer light converter seems unlikely, thankfully.
I'm using this experience to start a new thread on checking brake lights.
