We just got back from what is likely to be our last trip for the season. On Friday when hooking up I turned on the gas to cool down the frige while heading for our campground. The regulator made an odd buzzing sound and I could hear/smell a gas leak. Investigation discovered two spots in the hose from tank to regulator that had what I can only guess is squirrel tooth marks. I stopped at two RV dealers with the second one having a hose. The first one told me to make an appointment. I made a resolution not to stop there again.
Well at least you can know that you're not the first. Something about fuel lines makes rodents (squirrels, chipmunks, rats, etc.) think that it's tastier than a double cheeseburger at a Weight Watchers convention. I know of no easy solution to the problem except to maybe try to wrap the line with something metallic that can't be easily gnawed through (easier said that done I know). Maybe you could coat it with something that would make it taste bad to them. Or else place some D-Con close to your propane tanks?
